hi;
I would like use date format for user credite ,
e.g:
user1 credit start 01-09-2006
end 30-09-2006
please help me to slove this problem..
hi;
e.g:
end 30-09-2006
hi,
It is impossible to do this now with the available tools. Anyway you can write a script to do this task.
thanks jaafarkhalaf,
Can you give me small example about the script , where can I write it and how its run?
thanks.
If you would use a RADIUS server for your user database,
e.g. freeradius, you can use the "Expiration" attribute that
does exactly what you want.
e.g. freeradius, you can use the “Expiration” attribute that
I dont konw how to install “freeradius” please can you help me to install it!!
I was see this scripts “Radius Manager 2.0.2” http://www.dmasoftlab.com/index.php?cont=radman
its good scripts for my task but the problem is I dont know how I install the freeradius and where ??
thank you
You find freeradius at http://www.freeradius.org . Please have a look
at the Wiki and the online documentation.
freeradius is available as a package for nearly every linux
distribution. Install should be sinple for you. Configuration
with Mikrotik has been described in this forum (please use
the search function).
The Radius Manager Software you mention is a copy of the
free "Dialup Admin" that comes with the freeradius software.
Don't pay money for software that is free!!
you can do this with the user manager, can’t you?
user manager is very ‘‘low class’’ solution in compare to radius manager 2 + raidus + mysql/ldap/… ![]()
if you wish to configure it all by yourself - you’re welcome
usermanager just provides a quick solution to the hotspot/isp managers.
dear normis,
I can’t open http://gateway-ip/userman/ ??
how can I use user manager ?
I have the following packages
plz help.
First you have to create the ‘subscriber’, here is short description how to do that,
http://wiki.mikrotik.com/wiki/MikroTik_User_Manager
hello friend,
yes, userman already installed on your system, make sure at submenu '/ip ser set www disabled=no', and add manager login name by command '/too user-man cus' than add login name and password. [userman is not ready do from winbox] must be with console.
after create it go to http://your-router-ip/userman i think is working, when is success login you can add users from that 'userman web interface'
Hi All…
Who ican use the User-Manger and relate it with MikroTik PC (the users)?!!!
There is Nothing about User-Manger in Mikrotik manual?!!
plz help me to understand the User-Manger setting.
Thanks,
-leshwolek
You have to explore ‘User Manager’ forum section, there you will find more information about User Manager.
User Manager is used for management of HotSpot users, PPP (PPtP/PPPoE) users, etc.
E.g. HotSpot server can use User Manager (as well other RADIUS server) for clients authentication, authorization and accounting, instead of performing these actions locally on the router.
You can set multiple routers to use the one User Manager database for AAA.
To enable routers communication with UserManager:
also check your webservice port. if you have ever used hotspot, it changes the port to 8081 i think
hi,
Thanks sergejs for your help, Ido this step as u say
- Add router information in the ‘Router’ section of the user Manager web interface:
- Setup RouterOS RADIUS client
idon’t Know how can setting this?!!
- Set HotSpot profile to use RADIUS (use-radius=yes)
but it not work ?!!!plz any help.
Thanks,
-leshwolek
hi,
Plz Any Help !!!
hi,
Plz Any Help.
-leshwlek
