i m using 4 router every router in it static ip address how can i use mikrotik to out this static ip address and use it dynamic and static every router working static and dynamics
and this will increase upload
any one can help me
You may have to explain your intentions a bit clearer. I read that as you have a static IP setup you want to turn to dynamic, will this increase upload? Short answer would be No to that but please give more information so people can answer you a bit better.
Thanks my sir for replying
I have 4 routers every router have static ip address from my isp and every router work in the same time static and dynamics how to collect 4 router in mikrotik and how can mikrotik increase bandwith and work static and dynamics in the same time
I think I’m understanding this right then, so 4 ISP routers coming in and you’re effectively looking for a way to load balance across all of them?
I’d probably say you’ll need a 5th MikroTik to sit your side of the routers and do the balancing. Have you taken a look at the Mikrotik documentation for this?
https://wiki.mikrotik.com/wiki/Manual:PCC
https://wiki.mikrotik.com/wiki/Improved_Load_Balancing_over_Multiple_Gateways
Ha Steve, I love your response on this one. The answer is More COWBELL!!! (or in this case more mikrotik)…
(Its NA humour Steve, if you need git translation let me know).
