hi ,
i have 2 mikrotik router , config l2tp vpn . i can connect to local router with winbox . but i can not connect to remote router with winbox . how config 2 mikrotik router for connect with winbox ?
hi ,
Not seeing your firewall configuration, I would recommend always checking the vpn settings and the interface used for connection, check whether “arp=proxy-arp” is present.
https://jcutrer.com/howto/networking/mikrotik/l2tp-over-ipsec-troubleshooting
