How debug "eth0 no link"?
Hi to all, I’m having troubles on eth0 interface.
RB433AH (ROs 6.19) often says “no link”, always for 7 seconds, then “link ok”.
My topology is:
  • RB433AH A (ROs 6.19) → POE → switch1 → Router2 → My PC
  • RB433AH B (ROs 6.19) → POE → switch1 → Router2 → My PC
    For checking I also used netwatch to other RB (RB A pinging RB B, RB B pinging RB A), both RB pinging router and also my PC.
    Link is down randomly (sometimes I can’t ping other RB, sometimes I can’t ping only router, sometimes I can’t ping PC, sometimes several devices not pinging at same time), but all links down last always 7 seconds.
    I already changed POEs, I already changed switch.
    Power is ok (I haven’t power failures on log).
    I enabled debug messages on log, but I have no messages about routing or interfaces.
    When eth0 not working I can see leds switched off on my switch ports.
    Any idea about debugging?
I supposed I can try using a MAC ping (my configuration is eth0 and wlan1 as ports of same bridge, so MAC address associed to bridge could be eth0 MAC or wlan1 MAC) so I can’t get fixed MAC address to ping.
How can I solve this?
Thanks.
