Hi All
i want to prompt the client by redirecting the clients to a page either than the net if they are due to pay their monthly bills.
How do i do this without the client having internet access and have the message stored in the router board?
Rough steps:
- be able to identify clients that haven’t paid yet somehow (they will be assigned a predictable IP from a certain range only used for those customers, you manually have added them to an address-list).
- turn on the web proxy and add an access rule that denies all proxying with a redirect to a URL that warns the user about payments
- transparently proxy users that haven’t paid, the proxy will then deny the action and redirect them to the specified URL
If you need the page to be hosted on the RouterBoard, create an empty bridge and run a Hotspot on it, you should then be able to host the page within the Hotspot section and reach it from non-Hotspot networks (though I’m not 100% sure on that).
can you make a video on that or is their a tut on how to do it
I have a MT box as my backbone router, so I can use a NAT Rule under Firewall to redirect them to a webpage.
NAT Rule:
Chain - dstnat
Protocol- tcp
dst port- 1-200 (don’t want email etc to work either)
SRC Address List - Suspend
Action - dst-nat
To Address - xx.xx.xx.xx address that is page you want to come up
To Ports - 80
Adress Lists:
Name - Suspend
Address - xx.xx.xx.xx their firewall IP
Comment - the name of customer
Doesn’t take but a few minutes to make the phone ring.
i will try it and get back
