How do i turn off wireless on RB2011UAS-2HnD-IN
Using winbox and default settings as i am new to this device and networking in general.
I would like to turn off wireless for the time being how do i do this.
I have tried to disable wlan and when i do all of my machines lose internet connection.
Also i have been looking thru settings and im yet to find a setting that allows me to change my wireless transmit power. is there one ?
thanks in advance
Rebelspy
Open the Interfaces menu and choose “Wlan1”, then click “Disable”.
Ok when i do that what happens is the entire network stops responding. Dose it require anything else ?
if your users are connecting to wireless, of course they will disconnect if you disable wireless.
ok right now i have 3 machines all on lan using ports 2,3 and 4 i have nothing connected to wireless. When i disabled wireless the device routes me to my modem ip address on all of my lan computers. It seems to be bypasing the device when i disable wlan and trying to assign me an ip directly from my modem.
Please type “/export compact” in the terminal window, copy the output, and paste here. We will see why that happens
Did you check which interfaces are added to your bridge? I am not sure but If wlan1 is the only interface in your bridge then this may be the reason.
export compact
expected command name (line 1 column 1)
[admin@clyde] > export compact
oct/18/2012 02:33:34 by RouterOS 5.21
software id = MDMX-B7MN
add admin-mac=D4:CA:6D:62:FC:7F auto-mac=no l2mtu=1598 name=bridge-local
protocol-mode=rstp
/interface wireless
set 0 band=2ghz-b/g/n channel-width=20/40mhz-ht-above country="united states"
distance=indoors hide-ssid=yes ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290
mode=ap-bridge wireless-protocol=any
set 0 disabled=yes name=sfp1-gateway
set 1 name=Modem speed=1Gbps
set 2 name=Clyde speed=1Gbps
set 3 name=Jeff speed=1Gbps
set 5 name=Storage speed=1Gbps
set 6 name=ether6-master-local
set 7 master-port=ether6-master-local name=ether7-slave-local
set 8 master-port=ether6-master-local name=ether8-slave-local
set 9 master-port=ether6-master-local name=ether9-slave-local
set 10 master-port=ether6-master-local name=ether10-slave-local
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
supplicant-identity=MikroTik wpa-pre-shared-key=MAster
wpa2-pre-shared-key=MAster
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m
add name=dhcp ranges=192.168.1.1
add address-pool=default-dhcp disabled=no interface=bridge-local name=default
add address-pool=dhcp interface=wlan1 name=dhcp1
add bridge=bridge-local interface=Clyde
add bridge=bridge-local interface=Jeff
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=Storage
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=wlan1
/ip dhcp-client
add comment="default configuration" disabled=no interface=sfp1-gateway
add comment="default configuration" disabled=no interface=Modem
/ip dhcp-server lease
add address=192.168.88.252 client-id=1:5c:d9:98:b:0:9c mac-address=
5C:D9:98:0B:00:9C server=default
add address=192.168.88.254 client-id=1:bc:5f:f4:4a:99:35 mac-address=
BC:5F:F4:4A:99:35 server=default
add address=192.168.88.0/24 comment="default configuration" dns-server=
192.168.88.1 gateway=192.168.88.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add action=drop chain=input comment="default configuration" icmp-options=8
protocol=icmp src-address=192.168.88.1
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add action=drop chain=input comment="default configuration" in-interface=
sfp1-gateway
Modem
add action=drop chain=input icmp-options=8 protocol=icmp src-address=
192.168.88.1
add action=masquerade chain=srcnat comment="default configuration"
out-interface=sfp1-gateway
out-interface=Modem to-addresses=0.0.0.0
/ip neighbor discovery
set Modem disabled=yes
/ip service
set telnet disabled=yes
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=no
/ip upnp
set enabled=yes
/system clock
set time-zone-name=America/Detroit
/system identity
set name=clyde
/system leds
set 0 type=flash-access
/system ntp client
set enabled=yes mode=unicast primary-ntp=65.55.21.13
/tool mac-server
add disabled=no interface=Clyde
add disabled=no interface=Jeff
add disabled=no interface=ether4
add disabled=no interface=Storage
add disabled=no interface=ether6-master-local
add disabled=no interface=ether7-slave-local
add disabled=no interface=ether8-slave-local
add disabled=no interface=ether9-slave-local
add disabled=no interface=wlan1
add disabled=no interface=bridge-local
/tool mac-server mac-winbox
add interface=Clyde
add interface=Jeff
add interface=ether4
add interface=Storage
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=wlan1
add interface=bridge-local
Edit: All these are temp settings right now as i am learning how to use this device. Most settings are default the way it came. What i would like to do later on is run each port non bridges to different networks. Right now tho i would like to figure this problem out before i go any further. Thanks for your time.
I think this is the issue:
remove this address from your router. then paste this command into your command line:
/ip address add address=192.168.88.1/24 comment=“default configuration” interface=bridge-local
Awesome can you explain how i would do that in winbox ? Thanks :slight_smile:
Actually in winbox it’s even easier. Open “IP” → “Address”. Double click the address “192.168.88.1” and change the interface from Wlan1 to Bridge-Local. Then you can disable wireless and LAN will work
it gives me an error saying the couldent change adress already have address
ok i tried something and it seems to work
i changed the wlan ip to 192.168.1.1/24
with a network of 192.168.1.0
then rebooted the device and now i am able to disable wlan and keep the network running.
Is that setting ok to use for the wlan ?
protocol-mode=rstp
/interface wireless
supplicant-identity=MikroTik wpa-pre-shared-key=********
wpa2-pre-shared-key=********
add address=192.168.1.1/24 comment="default configuration" interface=wlan1
bridge-local
/ip dhcp-client
/ip dns static
sfp1-gateway
add action=drop chain=input comment="default configuration" in-interface=Modem
192.168.88.1
sfp1-gateway
192.168.88.1
/ip service
set api disabled=no
/ip upnp
set enabled=yes
/system clock
/system identity
set name=clyde
/system leds
/system ntp client
/tool mac-server
add interface=Clyde
add interface=Jeff
add interface=wlan1
Also i went into bridge-ports and removed wlan from the bridge. i hope i did it right
The RB2011UAS-2HnD-IN comes pre-loaded with a configuration in which the Wireless interface is the only interface that has a static IP assigned to it. As far as i remember it is 192.168.88.1 correct? Anyway mine came with 192.168.88.1 assigned to the wireless interface. By disabling the Wireless interface you loose connectivity to the router and you have to reset it with a screwdriver using the bottomhole. I’m no routeros expert at all but I would : first remove ether10 from the local-bridge, then assign ether10 a static ip 192.168.88.2 etc, connect your laptop to the router using a patch cable plugged into in ether10, then fire up WinBox and try to connect to 192.168.88.2. If you succeed to connect then the disable the wireless interface. From now on you should be able to connect through ether10 or any other port but ether1 which is configured to be WAN dhcp’ed.
Best regards
hello
i have the same question for my RB2011UAS-2HnD-IN.
i am using v5.22 and changing the Antenna Gain does not change anything.
how do you reduce the RF output power for the wireless then? :open_mouth: :question:
[admin@MikroTik] > export compact
dec/18/2012 14:23:52 by RouterOS 5.22
software id = PE5S-JVPX
add admin-mac=D4:CA:6D:7C:63:16 auto-mac=no l2mtu=2290 name=bridge-local
protocol-mode=rstp
/interface wireless
set 0 antenna-gain=99 band=2ghz-b/g country=canada disabled=no distance=
indoors frequency=2462 ht-rxchains=0,1 ht-txchains=0,1 l2mtu=2290 mode=
set 0 name=sfp1-gateway
set 1 name=ether1-gateway
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether5
bridge-local
/ip dhcp-client
add comment="default configuration" disabled=no interface=ether1-gateway
/ip dns static
add chain=input comment="default configuration" protocol=icmp
sfp1-gateway
ether1-gateway
out-interface=ether1-gateway to-addresses=0.0.0.0
set sfp1-gateway disabled=yes
set ether1-gateway disabled=yes
set wlan1 disabled=yes
/system clock
set time-zone-name=America/Montreal
/system ntp client
set enabled=yes mode=unicast primary-ntp=128.138.140.44 secondary-ntp=
165.193.126.229
/tool mac-server
add disabled=no interface=ether2
add disabled=no interface=ether3
add disabled=no interface=ether5
add interface=ether2
add interface=ether3
add interface=ether5
add interface=wlan1
[admin@MikroTik] >
set the card to “all rates fixed” first, only then the tx-power setting will have any egfect
hello
i there another setting somewhere else to change the RF output power?
i played with that (all rated fixed, tx-power) and i discovered i could change TX POWER from minus 30 to plus 30, and, although i saw just a small change in RF power output. no matter how low i tried to change it, my iphone was still able to browse on the net and my inSSIDer (pc software) displayed a mikrotik ssid that was indeed powerfull enough to be used at quite a long range.
what is the purpose of the ANTENNA GAIN setting? setting it to 0 or to 30 didn’t seem to have any affect.
i need to get the RF output as low as i can, and at -30 it ain’t low enough.
Antenna gain is used to calculate total radiated power. Different countries have different regulations on ERP (effective radiated power) and the router will help make sure you aren’t exceeding that (it will lower power when you are above the ERP because you have a high gain antenna). This is also a reason why it wants you to set your country.
There are two places to set power. You can set power to let the card just max out it’s rated power or you can specify power for each speed rating. Just remember you have to point the router to which one you want it to use. I believe this router is set to max out on the rated TX power.
P.S.: I forgot to tell you. Since you are using tx-power=-30 you will need to make sure the following is changed:
tx-power-mode=all-rated-fixed
That will point the router to the value you put in tx-power. If you haven’t done that, that is why your power levels don’t seem to be changing.
i too thought it would of been as easy as “Open the Interfaces menu and choose “Wlan1”, then click “Disable”.”
but disabling the Wlan1 interface locked me out of my unit
it seems that my config as well had this error and it makes me wonder if this was a default entry
if it was a default config entry, then please take that person responsible for that brilliant line of code and proceed to give him/her 50 lashes with a network cable
I would like to know how to change the wireless power on the RB2011UAS-2HnD-IN.
What is the exact command?
Thanks,
Don James
