how i can disable and then enable pppoe users automatic ?
Hello dear friends:
I’m working in a company. The company has about 60 Internet users. All of these users are pppoe connected to the Internet. The head of the company has ordered some users to use the Internet at certain times. For example, from 7 am to 5 pm.
How many ways to do this? Tell me the easiest way. For example, a pppoe user named James at 7 o’clock in the morning and 5 o’clock in the afternoon will be deactivated and tomorrow will be back at 7am to the internet and …
One friend told me with the Scheduler method but unfortunately I forgot.
Thank you very much for your dear friends.
If you want to enable/disable then and are using local user accounts, then you’ll need to program a script to do so, and use the scheduler.
Another possible approach would be using time feature on simple queues, not to disable them, but to apply restrictive speed limits to them: you can use IP address range for this (making sure users with same time limits share same range).
The third and more complex one, use radius for user auth/aaa.
Thanks my dear friend
Please explain first line. (Script and scheduler).
I do not know well. Please explain step by step.
Please answer my question .
Sorry, this is an user-supported forum, there’s a Scripting forum where you can post more specific questions.
