How I do to install a second drive for web proxy
Hello, and thanks for help me, I have running mikrotik OS on PC over compact flash and I want install a hard disk drive to be used by web proxy, must I install a drive and reinstall router OS again or simply install hard dirve and start system?.
thanks in advance.
ARIEL
Install the sencond HD and select secondary on webproxy
Max
Maxi, thank you very much, my name is ARIEL, my amateur radio license is LU7MBE, I remember you since packet radio, very cool times!
thanks again
ARIEL
I have a Rb532a, and I would like to attach a 7200RPM 200GB 2.5" SATA harddrive to it. Can it be done? If so where would I look for instructions on how to do it?
Ariel: send me you msn to elmaxi[at]gmail.com. I remember those years. Look where we meet again, crazy not?
Max
Yes, TCP/IP never well dead, in a way or of the other, we will continue transmitting packets!!!
I send a mail.
thanks again.
ARIEL
rb532 only has the Compact Flash slot no SATA port. Compact Flash is similar to ATA/IDE but it would be difficult to arrange a power supply and adapter for a IDE/PATA hard drive. And then the compact flash controler on the routerboard probably wouldn’t know how to mount the hard drive.
Instead just get a large compact flash card, 8,12 & 16 GByte cards are available. Another alternative would be a IBM micro-drive that uses a compact flash interface. Seagate also makes a hard drive in a Compact Flash form factor.
If you want a 2.5" drive you could just install RouterOS on a mini-ITX x86 system. I just use the parent proxy setting instead and point it to my Linux proxy server in my NOC with large and fast drives.
