How initialized a variable by SMS ??
I want to know How initialized a variable by sending SMS to mikrotik?
I do these steps:
1-Create a startup script in (\system\schedule) like this:
2-Create another script named SMSScript in (\system\scripts) like this:
3-Send a SMS To mikrotik,such as:
:cmd mypass script SMSScript myvar=value2
After that, the SMS received and the script runs.
But variable (myvar) did not receive the new value.
Where is the problem??? :frowning: :confused:
___I also use this Link for my purpose : http://wiki.mikrotik.com/wiki/Manual:Tools/Sms
wow, More than 50 visitors and no one had any advice. :question: :neutral_face:
I don’t think you’re actually setting a value with the line
:global myvar
to begin with.
Try to explicitly set it to an empty string or whatever you want the new value to be, like:
:global myvar ""
Well, you got some advice. How did it work out?
Hello MikroTik forum,
it is not working also for me with suggested examples. I created Ticket#2012083066000462 for this, let’s hope that we will get the solution.
Hello MikroTik forum members,
there was a bug confirmed by MikroTik team, it should be fixed in next release.
3.30-5.21 the bug very long!! :smiley:
Last reply from MikroTik support is that the bug will be fixed in 6.x version, in next release from 6.0r2, I’m keeping the ticket opened for this :slight_smile:
There was no update from MikroTik support team for more than month, I have opened a new ticket for this bug - Ticket#2013010766000731
DjM, any news?
Unfornatelly nothing - no information in changelog of ROS 5.x or 6.x, also no asnwer on both support tickets.
@MikroTik support team: Please provide update on this issue which is open for more than 2 months.
Thank you
Any progress?
There is still no update from MikroTik support team’s side on [Ticket#2013010766000731]. There was no reply on reminders send on 29/May and 21/May, also no information in releaselog of ROS that the issue has been fixed. I have send another reminder to support team on 03/June, let’s hope that there will be an answer. :confused:
Update on 4/June 2013:
I have received information from MikroTik support team, that bug is reported to developers, but there is no ETA/schedule, when the bug will be fixed :confused:
:global FanTempCount;
:if ($FanTempCount >= 0) do={
} else={
:set FanTempCount 0;
hold on!
Hello MikroTik support team,
what is the current status of solving this bug, please?
Thank you
hold on!
Hi vipe,
can you, please, share more details about your ticket?
Thank you
So, um, has this seriously NOT been working for the last 2 years?
I just tried to implement argument passing from a SMS, but I found it doesnt work.
So right now I dont know if Im doing something wrong, or if this is still broken.
