How many maps?
How many maps are there possible?
I had made a lot of maps for al the locations we have. But some maps can not be opened.
If you want to open a map there standing LOADING… butt the map wil not be opened
Is there a solution or is there a maximum for the maps?
Thank u
Tim
I too have the same problem. I have just started using the Dude v2.2 on Windows Server 2003 and Windows XP (which we have been very impressed with), and whenever I create a new map and try to show it, the windows pane comes up and just says “Loading” and doesn’t load anything.
Does anybody have a solution for this?
I had this problem myself…I just kept clicking and creating new maps.
You may want to try playing around with the default map image/color.
