Hello all,
I have a customer with about 130 users in 2 nodes. These 2 nodes are connected via 5GHz link, without NStreme. It’s about 20 Mbps TCP 100% CCQ.
These 130 users are getting access with a 493AH hotspot, connected to one 433AH AP (node 1). The 493AH only makes qos and hotspot, but I have always the CPU at 50%.
Resuming.. I have 2x433AH nodes connecting with 130 nanostations2 in 2.4GHz. This is a rural area without many interferences.. but… There are too many users for using this network at 2.4GHz? May I change 50% of users to 5GHz? I’m having problems with bad pings (50ms-150ms of latency) when about 40 users working. It’s not problem of internet connection (using 6 of 10 Mbps), and the CPU of the 493AH don’t arrive to 80%. Where is the problem? There are only 3 users that have less than -50 of signal. The other users are at about -50 -85.
Thanks,
