My personal opinion:
I've used Extreme Networks, Ruckus, MikroTik, HPE Aruba, Lancom, SonicWall and Ubiquity in a professional and private context.
My favorites are:
Mikrotik for routing and switches. Hardware is well-made and very robust, especially for this price-performance ratio. Even harsh environment condidtions are capable, like hot/warm rooms etc.. There are no wizards, helpers or whatever, except the quick configuration option. You have to know what you are doing. Personally I find it very pleasant that Mikrotik isn't doing some snakeoil cybersecurity stuff - especially if this "security enhancing" stuff tends to phone home or requires expensive subscriptions. However, the user interface is very straight forward, I am more like the visual guy than the CLI guy when it comes to networks. My oldest switch is over 10 years old and still gets RouterOS Updates up to Version 7.
Mikrotik for WLAN if you only need one or two APs and don't have high demands for WIFI. As much as I love Mikrotik for their routers and switches, WLAN is not their strength IMHO.
Ubiquity for WLAN APs, when you are on a budget. Easy to configure, reliable, very good price-performance ratio.
Ruckus for WLAN APs, when you have enough budget and/or need exceptional WIFI-Performance. Easy to configure and not that expensive, if you compare to other competitors.
Again, this is my personal opinion, all brands I have used have strengths and weaknesses. The ones above are my personal favorites. About personal taste, you can't discuss.
In a lot of professional environments there will be a challenge to use MikroTik. There are too many so called professionals, who don't know/want MikroTik and are talking poorly about it, without any plausible evidence. If there is the slightest network issue, by default the MikroTik stuff is the reason, because its not one of the big old networking company stuff, and because that, it must be automatically bad. You have been warned and should be able to handle these kinds of professionals.
