I’m trying to add RDP (Remote Desktop Protocol) probe.
I add TCP probe for port 3389 ‘connect only’ but this does not work.
Same problem with RADMIN (Remote Administrator) probe.
I add TCP probe for port 4899 ‘connect only’ but nothing.
Please help.
Please help.
I use rAdmin and RDP, let me know if you find a syntax to probe these services.
I was trying to add an RDP probe today by adding a new TCP probe and setting the port to 3389 and checking the “Connect Only” check box.
This does not work.
I think the “Connect Only” option on probes is just broken in The Dude 3.4.
Can anyone confirm this?
I have a connect only probe for HTTPS. I set it to port 443 and connect only it works ok.
Any solution until now ? How to set a RDP probe?
I am using v4.0b2 and setting up a RDP probe as TCP and Connect Only works fine. If it is not working in older versions it could be a bug with that version.
You’re right…I did a test with Dude v4.0beta2 and it works…
Thanks ![]()
