Hi, I am having a puzzling issue with Router OS on a hExs and an HP 102w wireless printer, currently I cannot access the printer from any computer or device connected to the wireless network (which is also on a Mikrotik cAP ac and controlled with CAPs MAN). If I use the ping feature its possible to detect the printer but windows and HP apps cannot, I think that it could be related to the configuration of the firewall but I am a non technical user using an standard configuration. my question is related on how to open the ports related to the printer (9100, 161 and 631) for the devices on the network to be able to see the printer and use it as needed. Thanks
Check the checkbox the “client to client forwarding” in the datapath of the capsman
