I have mikrotik with 2 isp connections and have forwarded ports from both to my mikrotik
When I try to connect from internet side I am only able to connect from isp which default gateway 0.0.0.0/0 is pointing too.
How can I make that I can connect from both isps without needing to change the default gateway to point to second isp
It’s not about the incoming traffic, rather the returning traffic which takes the default route unless you use connection marking on the incoming traffic.
