Hi!
I’ve successfully blocked TeamViewer with layer7 and packet marking, but AnyDesk still connecting, but with delay.
AnyDesk website blocked, but previosly downloaded binaries connecting after some delay.
WireShark shows DNS requests to playanext and soflopxl, but blacklisting of them doesn’t work.
Does anyone have success with AnyDesk blocking or any suggestions?
Check server connections using GlassWire on Windows.
Regards.
Do the following.
- Block Port 6568 tcp and udp
- Block *.net.anydesk.com Doamins
- Block other DNS Servers
- Block hardcoded ip’s
In my test the static ip’s ware 5.9.51.75 and 37.61.223.15. But this may change.
Blocking IP may can give problems. Example AnyDesk server is on a big amazon server with hundreds of other web servers. Then you block them all.
