How to block custom DHCP Server?
My ISP has DHCP server, but there are some other DHCP servers in their network. I have tried to block them with firewall filter.
add action=drop chain=forward in-interface=ISP protocol=udp src-address=192.168.0.xxx src-mac-address=AA:BB:CC:DD:EE:FF src-port=67,68
add action=drop chain=input in-interface=ISP src-mac-address=AA:BB:CC:DD:EE:FF
add action=drop chain=forward in-interface=ISP src-mac-address=AA:BB:CC:DD:EE:FF
The counter is rising, but the DHCP Client still accepts offerings from other DHCP servers.
Any idea how to block them?
Not sure if DHCP client binds to raw socket (as it does in most slinux distributions). In this case your only option is to drop packets in /ip firewall raw
Thank you! I have just tried, it count the packets but still accept other server offering.
Euh, call your ISP to fix this or have it clarified ? I mean, this is happening on the WAN-side of your connection right ? I would not care even if they have 20 DHCP-servers, it might be there for a REASON. And as long as they only “serving” my WAN-interface to the ISP.
Eg. multiples DHCP’s with split scopes etc.
Perhaps you are blocking some DHCP’s that at 1 point in time MUST provide your CPE with a working IP address.
I have talked to them 2 months ago, takled again today, but the problem still exists. And the dhcp servers are not theirs. They are clients… I couldn’t count on the ISP’s admins.
Really ? Hell, change ISP then :wink:
So this means from time to time your service does not work because you are getting some bogus IP address ?!
I cannot understand your ISP does not take action because this impacts the service you are paying for ?!
Try to create a rule to filter on OUPUT-chain! If you know the correct IP/MAC of the ISP DHCP-server try to construct something on output.
Hi remove isp port from bridge. not necessary
already natted pppoe client or dhcp client for internet.
or
you can try dhcp snooping on bridge settings
I have not tested what happens, but would be interesting to see how my ISP wold handle If I set up a device with fix public IP and DHCP server.
On our company network we do use ip dhcp snooping to prevent clients to setup their own DHCP.
