How to Block "Hola Better Internet" Add In
Dear All,
Hola Better Internet may be installed as a browser extension to Chrome and Firefox. It is also available as an application (.exe) for Windows (for users that are using Internet Explorer). and it is make the Internet faster and fully accessible to everyone.
some users use Hola Better internet in their browser to bypass firewall, how I can block this “Add In” in Mikrotik Fierwall?.
Many thanks,
I don’t know how this addon works, I’d install on a known computer and examine what’s visible in torch on the router. Then try to come up with a proper blocking rule.
Looks like it works similar to Tor, routing traffic to nearby nodes: https://hola.org/faq#in_whatis
Something to try (found on the web): The domain hola.org should be blacklisted. As of Hola version 1.4.450, the app primarily connects on ports 6851 and 6861 to multiple different IP addresses. The easiest method for blocking access is to create a drop firewall rule to block TCP traffic on those ports
Normis,
Thanks for your message,
i have tried today that script and these ips that the boy told me .. but , the script is not working ;/
i uploaded all ips in the mikrotik “Files” they are appearing there.. and after i put the script and click run, nothing happens, just counter of running script is working, but ips in the address list are not being added?
Can u help please?
it’s really important to block TOR shit ;/
