How to block multiple logins
Is there any rule to add multiple logins via ftp to a black-list address list? From time-to-time, I had some of these kind of logins, and they use different ip addresses every time.
14:12:24 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:26 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:27 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:28 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:34 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:37 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:38 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:40 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:41 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:42 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:44 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:46 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:47 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:51 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
14:12:52 system,error,critical login failure for user Administrator from 61.133.95.247 via ftp
Please advise.[/img]
keep your router login from …
and manage your router at submenu ‘/ip service’
regards
Hasbullah.com
allow connections to the router only from known IPs, also change the service ports, as balimore suggested
Thanks, done that.
I thought there is a known filter rule to capture this kind of traffic, and add it to a list automatically.
:rherry
they will stop working by themself, when you have stronge secure login from..
here we use one way only…don’t make many ways. it’s basic secure…!!!
regards
Hasbullah.com
