how to block sites in new proxy ?? Don’t work older proxy exoressions !! exmaple: 2.9 and beta 3.10, give-me examples please !
You can do a decent job of blocking sites by name by setting up an acct at “opendns.com” and pointing you DNS to them.
This wont block all access by IPs but most coders use URLs when referancing objects, so the majority of objects that are loaded on an objectional page being caught in the DNS filter and therefor failing to load..
Things that make you go Hmmmmm…
Craig
I need block some sites or expressions , example= msn, chat, etc.
I need block with proxy acess, help-me please
Beta 3.10
If you sign up (create an account (free)).. you can create your own block list..
The embeded proxy, uses the dns dettings of the router for resolution.
Craig
