How to bypass 4096 bytes variable size
I'm working on script which will run Bandwidth Test, save result to variable, send email with result, save result to disk and send it to FTP (where I create graph from values).
Script is working fine, till I reach the ANNOYING variable limit of 4096 and can't write to file anymore.
Here is the whole script:
:local rxc
:local rxcA
:local rxcB
:local rxcC
:local rxta
:local rxtaA
:local rxtaB
:local rxtaC
:local sysname [/system identity get name]
:local datetime "$[/system clock get date] $[/system clock get time]"
:log info "Bandwidth-test start"
/tool bandwidth-test xxxx protocol=tcp direction=receive duration=10s do={
:set $rxcA ($"rx-current" / 1000)
:set $rxcB ($rxcA / 1000 * 1000)
:set $rxcC ($rxcA - $rxcB)
:set $rxcB ($rxcB / 1000)
:set $rxc "$rxcB.$rxcC"
:set $rxtaA ($"rx-total-average" / 1000)
:set $rxtaB ($rxtaA / 1000 * 1000)
:set $rxtaC ($rxtaA - $rxtaB)
:set $rxtaB ($rxtaB / 1000)
:set $rxta "$rxtaB.$rxtaC"
:log info "Bandwidth-test done"
:log info "Sending info by email"
/tool e-mail send to="xxxx" cc="xxxx,xxxx" subject="Bandwidth-test done : $sysname" body="$sysname \n $datetime \n \n Result : \n RX speed $rxc Mbps/s \n \n RX total average $rxta Mbps/s"
:delay 5s;
:log info "Saving file"
/file
:if ([:len [find where name="test.txt"] ] = 0) do={ print file=test.txt; :delay 2s; set "test.txt" content="" }
set "test.txt" contents="$[get "test.txt" contents]$datetime,$rxc\r\n"
:log info "File saved"
:delay 5s;
:log info "Uploading to FTP"
/tool fetch address=xxxx src-path="test.txt" user=xxxx mode=ftp password=xxxx dst-path="test.txt" upload=yes
:log info "Upload done"
Than I tried different approach with using global variable and getting the data from
/system script environment print append where name="TimeVar" or name="rxc"
Columns: NAME, VALUE
NAME VALUE
0 TimeVar jan/28/2023 22:21:35
2 rxc 962.88
and saving them to file:
:set TimeVar ([ / system clock get date ] . " " . [ / system clock get time ])
/system script environment print file=$fileName append where name="TimeVar" or name="rxc"
As a result I have this in my file:
jan/28/2023 23: 3:14 by RouterOS 7.7
software id = DWYN-2ET8
NAME VALUE
0 TimeVar jan/28/2023 23:03:14
1 rxc 958.930
jan/28/2023 23: 3:18 by RouterOS 7.7
NAME VALUE
0 TimeVar jan/28/2023 23:03:18
1 rxc 958.227
But here I'm lost, because due to my poor skills I don't know how to parse it to output like in my .csv file:
jan/28/2023 23:03:14,958.930
jan/28/2023 23:03:18,958.227
Thanks for pointing to any direction.
P.S. I started scripting in RouterOS yesterday, so be kind please.
could you resolve your issue?
Are you aware of http://forum.mikrotik.com/t/the-maximum-size-of-a-read-written-file/167507/1 and http://forum.mikrotik.com/t/max-size-of-variables-still-at-4096-anwser-is-no/168007/3 ?
2023-01-28
2023-01-28 22:53:18
Last active:
2023-01-29 00:07:09
1
do not uselessly necroposting
