how to change mac in port????
hi to all
i have a question, here in Philippines one of the well known ISP is smart communication so called smartbro wireless services, there machine using mac authentication. for example once your computer connected to smartbro and the mac will register in smartbro machine or whatsoever they use, now how can i clone the mac address of computer to mikrotik box let say in ether1.
thanks
Doan
On ethernet interfaces, you can’t change MAC addresses, only wireless.
Regards.
You can, however, use bridge with ethernet interface as only port … you can set bridge MAC address to whatever you want.
from comand line - /interface ethernet set yourport mac-address=xx:xx:xx:xx:xx:xx
