how to change masquerade "to-addresses" or route pref-src
Hello there,
I have a peculiar requirement (at least, its peculiar in that I haven’t been able to find a solution myself!!!).
I have a dhcp-client running on a port, it is bridged to other ports connected to devices which we also need to get an IP address from the upstream router.
I also have a couple of WAN aliases on the port on the same subnet as the dhcp-client.
I have NAT masquerading set-up for the LAN (including the bridged clients).
This was set-up in the following order :
  1. dhcp-client
  2. additional aliases
For a while the masquerade rule performed as expected, masquerading all outbound traffic to the address obtained via dhcp.
Since a power cut and a subsequent router reboot, one of the aliases has now become the forwarding address.
I’ve tried adding a “to-addresses” value to the masquerade rule which is (probably quite rightly) ignored.
I’ve tried adding a static route to the subnet on the output side, but as there is a dynamic route it takes preference and so the static route is not active.
Some config follows :
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 3   192.168.2.101/24   192.168.2.0     192.168.2.255   ether1
 4   192.168.2.102/24   192.168.2.0     192.168.2.255   ether1
 7 D 192.168.2.242/24   192.168.2.0     192.168.2.255   ether1
and routes as follows :
 0 ADS  0.0.0.0/0                          192.168.2.1        0
 4 ADC  192.168.2.0/24     192.168.2.101   techmedia          0
 5   S  192.168.2.0/24     192.168.2.242   ether1             1
I need the forwarded traffic to appear from the source 192.168.242.2 instead of the 192.168.2.101 currently - any ideas how to achieve this?
Many thanks!
Cheers./C.
Use action=src-nat
Thanks for the reply!
Is action=masquerade doing anything else that src-nat won’t do - i.e. does it need any further options (apart from the dst-address I need to add) that masquerade “assumes”?
Thanks again!
Thanks again,
Worked like a charm, and, of course, in my reply above I meant “to-addresses” instead of “dst-address” :wink:
Action masquerade is the same action src-nat only with one additional feature - it doesn’t require “to-address” option (it ignores this option) - this is very useful when your Public IP is dynamic and might change periodically
So masquerade for dynamic public IPs, src-nat for static. :wink:
Excellent, that’s exactly what I didn’t know!!
