Hi i achieve a connection with one of my two sxt’s with the OmniTIK but i am not sure if i am really in bridge mode.
Is there a way to check if my connection is in bridge mode?
Many thanx in advance!
-gio-
-gio-
Do you have a DHCP server on your OmniTik?
i don’t know! but i can access the interface of my OmniTIK from here ( left side menu IP–> DHCP Server i have this )
hi.
please send export from your config.with this code you can export your config.
/export file=config
http://cl.ly/1c0j1N2Q0Z262s0E3f1D
this is the “/export file=config” from the OmniTIK.
Do you need also thisone from the SXT?
I want to add that my speed is very very low under 1Mbps and from time to time the Connection lost totally.
What is the prefered Channel width? / What is the difference between 20/40 Mhz above HT and 20/40 Mhz below HT ???
