How to configure multiple vlan with hw-offload
I have not fully understood how to configure multiple vlan with the new hw-offload implementation.
Can someone put a configuration for the RB3011 or 2011 code on this forum?
Mikrotik is unclear about it.
Thank you in advance
You can find examples with the new hardware offloading feature as well as for pre-6.41 here:
https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features#VLAN_Example_1_.28Trunk_and_Access_Ports.29
Hello
What about RB3011?
How should multiple VLANS be configured on this RB3011?
Does this make sense?
I would like to have more explanation for this routerboard in terms of VLAN with hw-offload
If you follow / apply the link as provided by @artz, it is actually quite easy. Read the whole document, then apply/test on device, any questions, come back and we will help
I want on the vlan 200, 300, 400 individual IP ranges with dhcp-server on it.
vlan-200 = 192.168.100.0/24
vlan-300 = 192.168.101.0/24
vlan-400 = 192.168.102.0/24
How do I configure that with the hw-offload?
Router 3011 = router with the 3 different IP ranges
Trunk ether2 as in this example goes to RB 260GS (SwOS
I think with this example like Mikrotik examples that this is not possible
But I can be wrong
Greatings and thanks for your reply
It is still possible but you have to keep your bridge without VLANs (and vlan-filtering=off) and put the VLANs on the switch chip.
This is confusing. A bridge with VLAN filtering and hw-offload should translate into the proper switch config automatically.
However, once you know it and you stay away from VLAN filtering on the bridge itself, it is still possible to do it on the switch.
I still do not understand.
The examples are indeed without IP addresses.
On my RB3011
This is my export
add name=bridge1 protocol-mode=none
add independent-learning=yes ports=ether2,ether3 switch=switch1 vlan-id=200
add independent-learning=yes ports=ether2,ether4 switch=switch1 vlan-id=300
add independent-learning=yes ports=ether2,ether5 switch=switch1 vlan-id=400
add address=192.168.100.1/24 network=192.168.100.0
add address=192.168.101.1/24 network=192.168.101.0
add address=192.168.102.1/24 network=192.168.102.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add action=masquerade chain=srcnat out-interface=ether1 protocol=tcp src-address=192.168.100.0/24
add action=masquerade chain=srcnat out-interface=ether1 protocol=tcp src-address=192.168.101.0/24
add action=masquerade chain=srcnat out-interface=ether1 protocol=tcp src-address=192.168.102.0/24
/system routerboard settings
set silent-boot=no
Hallo,
i think you need a vlan interface for each for your vlans under the bridge, so the cpu can access the traffic and can NAT it. Then assign your ip address to the vlan interfaces.
You need to add a VLAN interface for each of your VLANs with parent “bridge1”,
and with the correct vlan-id for each. I use names like bridge1.vlan200 so they are
easier to remember. That will be the router-side of each VLAN.
You also need to add the cpu port as a member on each of your vlans in the switch.
The IP addresses should be assigned to the above 3 VLAN interfaces.
This works for me, but am sure there are better ways to do it though and it’s still a work in process.
RB750Gr3
add admin-mac= auto-mac=no name=bridge protocol-mode=none
set [ find default-name=ether1 ] name=ether1.HUG
set [ find default-name=ether2 ] name=ether2.CRS112
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1.HUG max-mru=1492 max-mtu=1492 name=Movistar use-peer-dns=yes user=adslppp@telefonicanetpa
/interface vlan
add interface=ether2.CRS112 name=vlan10_PC vlan-id=10
add interface=ether2.CRS112 name=vlan12_WiFi vlan-id=12
add interface=ether2.CRS112 name=vlan14_TV vlan-id=14
add interface=ether2.CRS112 name=vlan15_MGMT vlan-id=15
add comment=defconf name=WAN
add comment=defconf name=LAN
add bridge=bridge interface=ether2.CRS112
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add independent-learning=no ports=ether5,switch1-cpu switch=switch1 vlan-id=10
add independent-learning=no ports=ether5,switch1-cpu switch=switch1 vlan-id=12
add independent-learning=no ports=ether5,switch1-cpu switch=switch1 vlan-id=15
add independent-learning=no ports=ether5,switch1-cpu switch=switch1 vlan-id=14
add interface=bridge list=LAN
add interface=ether1.HUG list=WAN
hAP AC
set [ find default-name=ether3 ] name=ether3.GabrielPC
set [ find default-name=ether4 ] name=ether4.TV
set [ find default-name=ether5 ] name=ether5.CRS112
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MOVISTAR_62DF \
    vlan-id=12 vlan-mode=use-tag wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MOVISTAR_62DF \
/interface vlan
add interface=ether5.CRS112 name=vlan15 vlan-id=15
set 0 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 1 default-vlan-id=1 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=14 vlan-header=always-strip vlan-mode=secure
set 4 default-vlan-id=1 vlan-mode=fallback
set 5 vlan-mode=fallback
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys supplicant-identity=MikroTik
add bridge=bridge interface=ether3.GabrielPC
add bridge=bridge interface=ether4.TV
add bridge=bridge interface=ether5.CRS112
add bridge=bridge interface=sfp1
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
add independent-learning=no ports=ether5.CRS112,switch1-cpu switch=switch1 vlan-id=15
add independent-learning=no ports=ether4.TV,ether5.CRS112 switch=switch1 vlan-id=14
add independent-learning=no ports=ether3.GabrielPC,ether5.CRS112 switch=switch1 vlan-id=10
add independent-learning=no ports=ether5.CRS112 switch=switch1 vlan-id=20
add interface=ether1 list=WAN
There is a CRS112 between them but its config is not relevant to the question. RB3011 has 2 switch chip 1-5 and 6-10 https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features you could create 2 bridges and do the vlan config in /interface ethernet switch you’ll get hw-offload on all interfaces in both bridges.Don’t know if adding them all to 1 bridge and doing the vlans would enable hw-offload on all interfaces, @CZFan can clear that up for you.
Reading the above, you should use config what they call “Router on a Stick” for the VLAN’s, i.e. the VLAN’s are on the switch (RB250GS) with a trunk uplink port to RB3011(Ether2)
In this case, ether2 on RB2011 should not be part of a Bridge but standalone, with VLAN’s 200, 300 400 attached to ether2.
Have a look at this example:
https://wiki.mikrotik.com/wiki/SwOS/Router-On-A-Stick
This configuration work perfect.
See on my website to the result.
https://www.wirelessinfo.be/port-based-vlan-met-mikrotik-swos/
Tis working like i want.
My question is this correct?
The link currently returns 404 and I cannot see a post with that title in the Mikrotik section. Work in progress?
Hello, I know, I’ve updated Social Warfare and there were bugs.
That’s why I had to put back an earlier backup.
I will return the article as soon as possible
This article is back https://www.wirelessinfo.be/port-based-vlan-met-mikrotik-swos/
I’ve double-checked but I can still see the topic to deal with configuration of RB750 (hence RouterOS) and your article to deal with configuration of RB260GS (hence SwOS). So what kind of feedback you actually expect from the forum at this stage :slight_smile: ?
I found the solution, with this configuration works everything fine.
But if i set “use service tag” on the RB3011 it don’t work anymore.
Strange, because the trunk should normally support vlan-tagging
Thanks for your quick responce to all people here on this Mikrotik forum.
Nice site plisken! Luckily I have learned how to google translate the pages. :slight_smile:
I’m afraid it is just a misunderstanding. The “use service tag” option actually means “apply VLAN tags with ethertype value of 0x88A8 instead of the ‘normal’ ethertype value of 0x8100” and is used at places where the context implies that the frames are always tagged. Where both tagless and tagged packets are plausible, there is a choice between “no tag, use tag, use service tag”.
So if there is a checkbox “use service tag” and it is not checked, the packets are tagged with the normal VLAN tag.
The idea behind is that “service tag” is used by service providers to provide “transparent L2” services for customers, where the service provider tags everything with a service VLAN ID at ingress and removes the service tag at egress, regardless whether the customer packets are tagless or tagged with normal VLAN tags.
@sindy you beat me to it.
if you enable service tag (s-tag) you’d just be tagging with 802.1ad which is a tag isp uses to switch traffic and to indicate that their is another vlan tag inside it, the actual (c-tag) customer tag that comes out to the customer. So that wouldn’t work unless some one is prepared to receive it on the other side with matching s-tag and c-tag.
