hope you are all fine. I wonder if someone can give me good advice. I have a chateau 5g router, which is placed on my roof.
My second router in the cellar is a RB3011UiAS.
First of all I would like to know where I can configure the APN (need a fixed official IP Adress).
And then I would like that the RB3011 will get this official IP Adress.
I was using a Zyxel NR7101 Router and IP passthrough was the standard setting.
So all in all my LTE router should work as a normal modem brindge.
Thanbks in advance for your help.
Regards.
Arthur Mössmer
