how to connect my router via winbox from any pc out of my la
how to connect my router via winbox from any pc out of my lan
please help me .
Can you clarify?
Type in the IP address?
you can do it by using the real ip ( ip from your ISP)
thanks par441
i use real ip , but this real ip open “my router conexant” not my my server
please some details .
if your router is inside your LAN and does not have real IP address to connect to from outside then one of the best solutions is to create tunnel to your border router and get into your local net that way, than - as usual - connect to router using winbox
