How to create auto-upgrade server
Hi, …
Can anybody please tell me is there a way to build my own MikroTik auto-upgrade server without using the MikroTik RouterOS ?
I want to create an auto-upgrade server using another OS, preferably FreeBSD, or other UNIX based operating systems
Thx
I think it is possible only with MikroTik router. One router should be the server, where other routers download packages.
You can use The Dude for monitoring the network, it has many features (one of them flexible upgrade of the MikroTik routers).
