how to create .npk file
Hi all,
Recently I am going to install my customized packages in my routerboard. I know that the extension is .npk.
So how can I make customized npk package?
Thanks.
Anton.
Forget create .npk file.
NPK is a closed format that only MikroTik themselves uses. It’s not intended for 3rd parties to create RouterOS add-ons.
Whatever it is you want to do, you’ll need to either implement it on a separate device by connecting to RouterOS via the API (if it’s non-network thing related; e.g. a management or testing application of some sort), or ask and wait for MikroTik to implement it (if it’s networking related; e.g. support for an otherwise not supported VPN protocol or whatever).
You can check this:
http://routing.explode.gr/node/96
M.
Mmmm… fascinating…
Don’t get too excited about it. It is totally outdated, and doesn’t support any current packages.
All recent packages are signed with EC-KCDSA signature, and there’s no way to create a valid npk file unless you know a secret key.
this cool :sunglasses:
