how to create user of vpn account in userman ???
hi.guys..
i install mikrotik 5.7 on vmware workstation 7 and i set 192.168.1.88 on it and set gateway 192.168.1.1 on it..
my mikrotik have internet..
i configed mikrotik for vpn account pptp-l2tp and i enable www in services..
i go to 192.168.1.88/userman/ and i login to userman and set profile and set router..
follow this:
address 127.0.0.1
key = 1234
so i set this config on winbox in radius..
when i create one user and give to it username and password.. i cant connect to my mikrotik with this account...
plz help me i fix this problem...
my problem fixed.. by this guide:
hi
you must do this work’s:
1.add router in usermanager with ip address and password (127.0.0.1 pass 12345 or any password)
2.add a radius in mikrotik (winbox 127.0.0.1 same above pass 12345) and user manwith same ip and password and then check ppp
  1. winbox>ppp>secret>>ppp autication and accounting > check use radius(under secrets in ppp i must enable radius)
    4.(winbox)run pppoe server on your ethernet (select my profile that created pptp-l2tp)
5.create profile in usermanager and create username and password in usermanager
6.(winbox)>>in radius,>>check accept box for incoming port 3799
done!
