I wanna turn off WiFi at night due to security reasons or looking for a healthy rest time:
- 1 CAPsMan + cAP in the same box RB951U-2nd
- 1 cAP : wAP
Any help, thanks a lot!
Maybe this would help?
caps-man manager set enabled=on or off
Schedule the above code for the hours you want…
If you turn the Capsman manager off then all the provisioned Access Point won’t be able to communicate with the manager and will not stay provisioned.
Just make sure that the radios of the access points stay disabled after the manager is off..
Not working with on or off, need to change to yes or no
