I have several RB951Ui-2nD but RouterOS 6.32.4 doesn’t have option WPS for disable it.
Anyone know how to disable the WPS button?
Thanks a lot,
Thanks a lot,
Tyep in your terminal or just copy and paste ![]()
/interface wireless set wps-mode=disabled
in the future, you can find the wireless setting on the terminal by typing:
/interface wireless export
This command not exists in this version:
[admin@XX] > /interface wireless set wps-mode=disabled
expected end of command (line 1 column 33)
WPS not exists:
[admin@XX] > /interface wireless export
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country=spain disabled=no \
frequency=auto mode=ap-bridge ssid=XX wireless-protocol=802.11
Then why don’t you upgrade the RouterOS?
Also try /system package print
You may be using wireless-fp which does not support WPS anyway ![]()
[admin@XXX] > /system package print
Flags: X - disabled
# NAME VERSION SCHEDULED
0 routeros-mipsbe 6.32.4
1 system 6.32.4
2 X wireless-cm2 6.32.4
3 X ipv6 6.32.4
4 wireless-fp 6.32.4
5 hotspot 6.32.4
6 dhcp 6.32.4
7 mpls 6.32.4
8 routing 6.32.4
9 ppp 6.32.4
10 security 6.32.4
11 advanced-tools 6.32.4
In hAp lite version I had wps for enable/disable. hAp lite use smips routeros but it had wps in 6.32.4 version.
enable wireless-cm2 and reboot - WPS should be back. ![]()
hi, Double click your wireless interface, click advanced mode and you will see WPS option, now you can click and disable it!
Have a good day!
You want to disable WPS, but your version does not have WPS. So it is already disabled.
