How to display/list/download exportable firewall and other settings (not as "backup")?
Messed up my WinBox password the other day and had to re-do all of my settings, then realized that some settings, such as firewall rules, can be imported via CLI. Is there any reason why they cannot be exported as cleartext files or just be displayed on the screen for me to copy/paste?
I'd like to save as many settings as possible in cleartext, but not passwords, not certificates, not keys, preferably not usernames, just generic settings. Firewall rules is the main thing I'd like to export because it takes the longest to create/re-create from scratch.
Of course they can be exported :slightly_smiling_face:.
The command is "export".
Check detailed generic instructions here:
Forum rules - #5 by gigabyte091
Don't forget point #18 here (and its corollary):
GP & CSA (Good Practice and Common Sense Advice) for Mikrotik devices
Jest, do expoert in proper section
go to /ip/firewall and make an export
the other way is to make full export and post/share only the firewall part
Ignore only the firewall part, its rare in RoS that one can fix a problem by only looking at the firewall rules, as much of the config is integrated and different lines affect other lines in the config.
The standard export function /export file=anynameyouwish already provides a SAFE export.
However, ensure the following:
a. remove router serial number
b. remove any reference to any public WANIP information ( gateways, IP address etc. )
c. remove dhcp lease lists, not normally needed and may contain device info or names etc.
There should be no keys or passwords visible.
