How to enable more wireless "Country" in my Audience?
I bought an Audience US version and uses in Taiwan.
But only found “canada2” and “united state3” counties setting in wireless interface.
Is it possible to enable “taiwan” or other country settings in Audience?
In my experience, there is no such problem in my hp ac.
My hp ac could set to a lot of “Country” settings.
Already tried to use Netinstall without “Apply default config” option and the result is the same.
Should I buy EU version Audience to solve my problem?
There are devices that are manufactured only for use in USA, those you can’t unlock. This is why you should only buy from local authorized distributors.
