but it does not work. there is no wifi and its not possible to connect via lan port
i also tried to use netinstaller-method, but the device does not appear. https://wiki.mikrotik.com/wiki/Manual:Netinstall
Reset button
RouterBOOT reset button has the following functions. Press the button and apply the power, then:
Release the button when the green LED starts flashing, to reset the RouterOS configuration to defaults.
Keep holding for 5 more seconds, the LED turns solid, release now to turn on CAPs mode (total 10 seconds).
Release the button after the LED is no longer lit (~20 seconds) to cause a device to look for Netinstall servers (required for reinstalling RouterOS over the network).
Regardless of the above option used, the system will load the backup RouterBOOT loader if the button is pressed before power is applied to the device. Useful for RouterBOOT debugging and recovery.
The device just loops forever.
It never appears in netinstall window.
If i set the bootp ip in netinstall to the interface ip of the computer, netinstall crashes after a while.
I saw some videos where people uses the same ip as the pc, but the tutorial says it should be another, so i use same settings shown in tutorial, but no luck. never appears, just reboots forever.
not sure why mikrotik make it so complicated to reset a device.
