How to filter BGP route via AS number?
Hi.
I’ve created bgp filter with next rules:
0 chain=peer-in prefix=0.0.0.0/0 invert-match=no action=accept
1 chain=peer-in prefix=x.x.x.x/22 invert-match=no action=accept
2 chain=peer-in prefix=y.y.y.y/22 invert-match=no action=accept
3 chain=peer-in prefix=z.z.z.z/22 invert-match=no action=accept
4 chain=peer-in prefix=a.a.a.a/24 invert-match=no action=accept
5 chain=peer-in invert-match=no action=discard
For some reasom i can see only:
0.0.0.0/0 x=x.x.x.x/22 in routing table.
What is wrong with my filters?
One more question:
I have interconnect with AS (let’s say) 555.
Could anybody tell me right filter to receive route only from this AS(filter via ASnum)?
Somthing like on Cisco:
ip as-path access-list 4 permit ^555$
WBR.
The same as on cisco
/routing filter
add chain=bgp-in bgp-as-path=^555$ action=accept
and
add chain=bgp-in action=reject
To reject all other routes?
P.S
Do you have an idea why i can not see in routing table prefixes whitch is describe by 2,3 and 4 rules?
and
Yes, except that instead of reject use discard, it saves memory.
If you are sure that there are exactly such prefixes and previously all prefixes were discarded then try refreshing bgp peer.
/routing bgp peer refresh-all
