How to filter "ip firewall address-list"
Hello, I want print all the address-list records if the address is inside a subnet
If I enter the exact match, is ok:
 > ip firewall address-list print where address=46.229.168.10
Flags: X - disabled, D - dynamic
 #   LIST                      ADDRESS                                       CREATION-TIME        TIMEOUT
 0 D ;;; test
     test                     46.229.168.10                               jul/24/2017 13:06:13 11w2d3h14m29s
but if I run
 ip firewall address-list print where address=46.0.0.0/8
the result is null
There is any option to filter by network via console/API ?
Thanks!!!
up up! :slight_smile:
Any idea?
I know it’s an old topic, but the answer is simple using the list name:
/ip firewall address-list print where list="list_name"
Or using filter by address and not by address list name:
/ip firewall address-list print where address ~"46"
/ip firewall address-list print where address ~"192.168.1.[8]"
/ip firewall address-list print where address ~"55.[1]"
very cool, learned something new again, the part, thank you for sharing
You can use POSIX regular expressions, with some exceptions.
Cool, thank you
