I am trying to get an id via python and api:
api = connection.get_api()
list_address = api.get_resource('/ip/firewall/address-list/')
test = list_address.get(address="1.2.3.4")
print(test)
connection.disconnect()
The Output looks like this:
[{u'creation-time': u'jun/07/2019 16:23:33', u'list': u'port scanners', u'dynamic': u'true', u'disabled': u'false', u'timeout': u'1w5d27m59s', u'address': u'1.2.3.4', u'id': u'*62C'}]
But how can I get the ID only?
mrz
June 10, 2019, 8:52am
2
To get only specific parameter via API use proplist, wiki has all the info you need:
https://wiki.mikrotik.com/wiki/Manual:API#Command_description
And here is example:
https://wiki.mikrotik.com/wiki/Manual:API#OID
netbus
June 10, 2019, 9:22am
3
thanks for your reply but I not looking for OID but rather .id
test = api(cmd='/ip/firewall/address-list/print')
id = api(cmd='/=.proplist=.id')
brings:
librouteros.exceptions.MultiTrapError: no such command or directory (=.proplist=.id), no such command
Jotne
June 10, 2019, 11:10am
4
print gives names, find gives id.
In cli you can get id with this command
/ip firewall address-list find
The see the id
:put [/ip firewall address-list find]
mrz
June 10, 2019, 11:44am
5
brings:
Most likely you are doing message encoding wrong. You are trying to send =.proplist as a new separate command, not parameter for previous command.
Use our python reference example from our wiki:
https://wiki.mikrotik.com/wiki/Manual:API#Example_client
netbus
June 10, 2019, 1:53pm
6
I understand now:
/ip/firewall/address-list/getall
?address=0.0.0.0/8
=.proplist=.id
<<< /ip/firewall/address-list/getall
<<< ?address=0.0.0.0/8
<<< =.proplist=.id
>>> !re
>>> =.id=*1
>>> !done
I am using librouteros or routeros-api but there I cann’t find how to add this attributes
