Hi all.
I am writing a script to get the signal-strength (RSSI) from the wireless card, but I get different information depending on the Wireless mode.
Can someone explain why am I getting this?
On the other hand the Keyword “as-value” seems not to be working on mode “ap_bridge”
Any thoughts about this?
Running RouterOS version 6.40.8
TIA
Wireless in Mode: station
[admin@MikroTik] > /interface wireless monitor 0
status: connected-to-ess
channel: 2412/20/g(20dBm)
wireless-protocol: 802.11
tx-rate: 36Mbps
rx-rate: 54Mbps
ssid: eidpublic
bssid: FE:EC:DA:A1:75:C1
signal-strength: -71dBm
signal-strength-ch0: -71dBm
noise-floor: -115dBm
signal-to-noise: 44dB
tx-ccq: 67%
p-throughput: 17832
overall-tx-ccq: 67%
authenticated-clients: 1
current-distance: 13
last-ip: 8.8.8.8
802.1x-port-enabled: yes
authentication-type: wpa2-psk
encryption: aes-ccm
group-encryption: aes-ccm
management-protection: no
current-tx-powers: 1Mbps:14(8/14),2Mbps:14(8/14),5.5Mbps:14(8/14),
11Mbps:14(8/14),6Mbps:14(8/14),9Mbps:14(8/14),
12Mbps:14(8/14),18Mbps:14(8/14),24Mbps:14(8/14),
36Mbps:14(8/14),48Mbps:14(8/14),54Mbps:14(8/14)
notify-external-fdb: no
Wireless in Mode: ap_bridge
status: running-ap
channel: 2412/20/g
noise-floor: -116dBm
overall-tx-ccq: 75%
registered-clients: 1
current-distance: 1
current-tx-powers: 1Mbps:32(26/32),2Mbps:32(26/32),5.5Mbps:32(26/32),11Mbps:32(26/32),
6Mbps:32(26/32),9Mbps:32(26/32),12Mbps:32(26/32),18Mbps:32(26/32),
24Mbps:32(26/32),36Mbps:31(25/31),48Mbps:30(24/30),54Mbps:29(23/29)
[admin@MikroTik] > /interface wireless monitor 0 once as-value
[admin@MikroTik] >
