How to leave a free subnet in hotspot
I have a RB1100AHX2.
To port “ether1” (IP 192.168.1.1/24) is a ADSL conection and a hotspot is activated to port “ether2” (IP 192.168.100.1/24), that provides internet to the local network (LAN).
In the same LAN also exists a subnet (10.0.0.1/24). In that subnet there is a PC and some other devices (cameras, access points, etc).
From the moment I actvated the hotspot, I lost the connection between the PC and the rest of the devices.
Is there any way of excluding this subnet(10.0.0.1/24) by configuring the hotspot in a way so that in this spesific subnet communication between my PC is permited.
Thaks in advance.
You can bypass the pc and another devices from hotspot with ip binding option.
sent from my mobile phone using tapatalk
Dear c0d3rSh3ll thank you for your reply.
I have already binded all the devices.
It works only for internet trafic through the router. For example if i “ping” to any of the devices from the PC, eventhough I have binded all these devices, I get no response.
What I need though is the communication between a local PC and some other devices that are on a different subnet(10.0.0.1/24).
It would be very important to me if there was a way of excluding the whole subnet from the hotspot’s blocking system.
Thanks again.
You can also add the IP block on the walled Garden IP list so that hotspot users can access the IPs without logging in.
Dear nerdtron thank you for your reply.
I think “Walled garden” is not giving free comunication between all theese devices.
I need to have full free communication between all devices Localy, for the specific subnet.
Any other idea please?
I have done exactly the same setup.
Put in Walled garden Ip List in Src.Address 10.0.0.1/24.
