How to make TTL=1
I want to give internet on my users with TTL=1
How to make TTL=1
You can’t call this internet. It would be access to next router ![]()
I want deny access to next router.
you can do that in /ip firewall mangle
edit:
erm.. test before implementing if everything works as you intended ![]()
do not cut yourself out
does changing TTL affect on the speed of internet !!
because when changing TTL from 64 to 255 at chain=output , i got a good opening websites .
is there any idea !
but it is not recommended to change your TTl to 1 .
chain output does not affect your customer networks
it only affects router’s communication to outside network.
the only chain that can affect your customers network is FORWARD
you can use TTL=1 if you use it carefully - that way you can block all those users that are using some network devices other than switches (bridges). many interesting AP that do not use bridging will fail too.
