Is there a way to measure and track performance from MikroTik AP to a Mac computer?
I need to do some surveying; it would be great if there is a tool on mac to utilize Speed Test that is native from mac?
Thanks!
Thanks!
You can use the iperf tool on two PCs attached to your router/switch and then do some calcs…
If you have 2 MikroTik devices then you could use other methods, like:
https://wiki.mikrotik.com/wiki/Manual:Tools/Bandwidth_Test
https://wiki.mikrotik.com/wiki/Manual:Tools/Traffic_Generator
https://wiki.mikrotik.com/wiki/Manual:Tools/Speed_Test
Thanks. I suppose I would have to run MikrotTik software in a virtual machine to use those.
I also found Windows application, btest.exe, so I have run that under Windows VM on a mac. It seems to work fine, tho I will try to port it to wine.
Testing with the built in tools should not be used a true measure of performance as it uses the cpu for both the test and connectivity.
Only use iperf (or similar) between 2 capable PCs as a true measure of performance. Connect the 2 PCs directly and test first to see what they are capable of.
I am aware that built in testing is limited, but I need to asses general WiFi performance, and it would be quite hard to set up PC-PC performance test on a location where I don’t have any PCs and need to assess signal quality.
Thanks on noting iperf. I set up a second laptop as an iperf3 server.
Just some posting tip. ![]()
No quote the post above you. Only quote some part if needed. Use the “Post reply” button (below) instead.
No multipost. If you add some information, just edit previous post if someone has not posted in between. Bump is ok if someone has not replied on some time.
