I deployed the CGNAT at small ISP network (1000 pppoe users) who is using Mikrotik RouterOS as PPPoE Server for LAN users authentication & Linux base SYSLOG-NG server [with SSD disk] to store the CGNAT LOG. I have modified the syslog-ng code to LOG entries which have NAT word in the message, this have reduced unwanted entries.
But problem is that DB size is getting very large & any query to search for IP/Port takes long time. Typical LOG lines that are stores on the remote syslog server.
Jan/03/2020 10:48:43 firewall,info forward: in: out:ether1-wan, src-mac d0:bf:9c:f7:88:76, proto TCP (ACK), 172.16.0.199:54326->179.60.194.35:443, NAT (172.16.0.199:54326->101.11.11.252:41636)->179.60.194.35:443, len 40
Jan/03/2020 10:48:43 firewall,info forward: in: out:ether1-wan, src-mac d0:bf:9c:f7:88:76, proto TCP (ACK), 172.16.0.199:54326->179.60.194.35:443, NAT (172.16.0.199:54326->101.11.11.252:41636)->179.60.194.35:443, len 52
Mikrotik Firewall LOG rule (for pppoe users) is
add action=log chain=forward connection-nat-state="" connection-state=new out-interface=ether1-wan protocol=tcp src-address=172.16.0.0/16
How can I minimize the Query/log size ? can some one please share what is typical LOG size . Appreciate for any tips.
can anyone please share some experience/advice for this topic?
Don’t think you can do anything on the Mikrotik side. The fields of logging etc are what they are and you cannot mangle with it as far as I know.
I’m not sure if some script running on the Mikrotik side could be an “alternative” source and pre-process some logging. This will for sure take resources on Mikrotik box.
You are logging so much for regulatory/law compliance I guess ?
What are you using as a DB ? Howmany MBytes/day are you generating purely for NAT Logging ?
Try a product like SPLUNK that is designed/engineered for that ? With the free version you can process 500MBytes/day.
I use Splunk (free) also for all my Mikrotik events.
I am storing NAT syslog entries to file. ~2k devices generate around 20GB of data. every night these files are compressed . for short time log checking I am using graylog.
sup5
January 17, 2020, 1:02pm
5
Simply use fixed-NAT / alogrithmic-NAT / deterministic-NAT.
This code compresses /18 adresses into one /24 Prefix. By statically assigning 1008 Ports to each internal User.
Limitations: only UDP and TCP ist being NATed in a fixed way. ICMP is being NATed in the loose way.
GRE and other protocols aren’t NATed at all in this example. This might be added by someone else.
add action=jump chain=srcnat jump-target=000001-CGN src-address=100.64.0.0/18 comment=/18
add action=jump chain=000001-CGN jump-target=000010-CGN src-address=100.64.0.0/19 comment=/19
add action=jump chain=000001-CGN jump-target=000011-CGN src-address=100.64.32.0/19
add action=jump chain=000010-CGN jump-target=000100-CGN src-address=100.64.0.0/20 comment=/20
add action=jump chain=000010-CGN jump-target=000101-CGN src-address=100.64.16.0/20
add action=jump chain=000011-CGN jump-target=000110-CGN src-address=100.64.32.0/20
add action=jump chain=000011-CGN jump-target=000111-CGN src-address=100.64.48.0/20
add action=jump chain=000100-CGN jump-target=001000-CGN src-address=100.64.0.0/21 comment=/21
add action=jump chain=000100-CGN jump-target=001001-CGN src-address=100.64.8.0/21
add action=jump chain=000101-CGN jump-target=001010-CGN src-address=100.64.16.0/21
add action=jump chain=000101-CGN jump-target=001011-CGN src-address=100.64.24.0/21
add action=jump chain=000110-CGN jump-target=001100-CGN src-address=100.64.32.0/21
add action=jump chain=000110-CGN jump-target=001101-CGN src-address=100.64.40.0/21
add action=jump chain=000111-CGN jump-target=001110-CGN src-address=100.64.48.0/21
add action=jump chain=000111-CGN jump-target=001111-CGN src-address=100.64.56.0/21
add action=jump chain=001000-CGN jump-target=010000-CGN src-address=100.64.0.0/22 comment=/22
add action=jump chain=001000-CGN jump-target=010001-CGN src-address=100.64.4.0/22
add action=jump chain=001001-CGN jump-target=010010-CGN src-address=100.64.8.0/22
add action=jump chain=001001-CGN jump-target=010011-CGN src-address=100.64.12.0/22
add action=jump chain=001010-CGN jump-target=010100-CGN src-address=100.64.16.0/22
add action=jump chain=001010-CGN jump-target=010101-CGN src-address=100.64.20.0/22
add action=jump chain=001011-CGN jump-target=010110-CGN src-address=100.64.24.0/22
add action=jump chain=001011-CGN jump-target=010111-CGN src-address=100.64.28.0/22
add action=jump chain=001100-CGN jump-target=011000-CGN src-address=100.64.32.0/22
add action=jump chain=001100-CGN jump-target=011001-CGN src-address=100.64.36.0/22
add action=jump chain=001101-CGN jump-target=011010-CGN src-address=100.64.40.0/22
add action=jump chain=001101-CGN jump-target=011011-CGN src-address=100.64.44.0/22
add action=jump chain=001110-CGN jump-target=011100-CGN src-address=100.64.48.0/22
add action=jump chain=001110-CGN jump-target=011101-CGN src-address=100.64.52.0/22
add action=jump chain=001111-CGN jump-target=011110-CGN src-address=100.64.56.0/22
add action=jump chain=001111-CGN jump-target=011111-CGN src-address=100.64.60.0/22
add action=jump chain=010000-CGN jump-target=100000-CGN src-address=100.64.0.0/23 comment=/23
add action=jump chain=010000-CGN jump-target=100001-CGN src-address=100.64.2.0/23
add action=jump chain=010001-CGN jump-target=100010-CGN src-address=100.64.4.0/23
add action=jump chain=010001-CGN jump-target=100011-CGN src-address=100.64.6.0/23
add action=jump chain=010010-CGN jump-target=100100-CGN src-address=100.64.8.0/23
add action=jump chain=010010-CGN jump-target=100101-CGN src-address=100.64.10.0/23
add action=jump chain=010011-CGN jump-target=100110-CGN src-address=100.64.12.0/23
add action=jump chain=010011-CGN jump-target=100111-CGN src-address=100.64.14.0/23
add action=jump chain=010100-CGN jump-target=101000-CGN src-address=100.64.16.0/23
add action=jump chain=010100-CGN jump-target=101001-CGN src-address=100.64.18.0/23
add action=jump chain=010101-CGN jump-target=101010-CGN src-address=100.64.20.0/23
add action=jump chain=010101-CGN jump-target=101011-CGN src-address=100.64.22.0/23
add action=jump chain=010110-CGN jump-target=101100-CGN src-address=100.64.24.0/23
add action=jump chain=010110-CGN jump-target=101101-CGN src-address=100.64.26.0/23
add action=jump chain=010111-CGN jump-target=101110-CGN src-address=100.64.28.0/23
add action=jump chain=010111-CGN jump-target=101111-CGN src-address=100.64.30.0/23
add action=jump chain=011000-CGN jump-target=110000-CGN src-address=100.64.32.0/23
add action=jump chain=011000-CGN jump-target=110001-CGN src-address=100.64.34.0/23
add action=jump chain=011001-CGN jump-target=110010-CGN src-address=100.64.36.0/23
add action=jump chain=011001-CGN jump-target=110011-CGN src-address=100.64.38.0/23
add action=jump chain=011010-CGN jump-target=110100-CGN src-address=100.64.40.0/23
add action=jump chain=011010-CGN jump-target=110101-CGN src-address=100.64.42.0/23
add action=jump chain=011011-CGN jump-target=110110-CGN src-address=100.64.44.0/23
add action=jump chain=011011-CGN jump-target=110111-CGN src-address=100.64.46.0/23
add action=jump chain=011100-CGN jump-target=111000-CGN src-address=100.64.48.0/23
add action=jump chain=011100-CGN jump-target=111001-CGN src-address=100.64.50.0/23
add action=jump chain=011101-CGN jump-target=111010-CGN src-address=100.64.52.0/23
add action=jump chain=011101-CGN jump-target=111011-CGN src-address=100.64.54.0/23
add action=jump chain=011110-CGN jump-target=111100-CGN src-address=100.64.56.0/23
add action=jump chain=011110-CGN jump-target=111101-CGN src-address=100.64.58.0/23
add action=jump chain=011111-CGN jump-target=111110-CGN src-address=100.64.60.0/23
add action=jump chain=011111-CGN jump-target=111111-CGN src-address=100.64.62.0/23
add action=netmap chain=100000-CGN protocol=tcp src-address=100.64.0.0/24 to-addresses=3.2.1.0/24 to-ports=1024-2031 comment=/24TCP
add action=netmap chain=100000-CGN protocol=tcp src-address=100.64.1.0/24 to-addresses=3.2.1.0/24 to-ports=2032-3039
add action=netmap chain=100001-CGN protocol=tcp src-address=100.64.2.0/24 to-addresses=3.2.1.0/24 to-ports=3040-4047
add action=netmap chain=100001-CGN protocol=tcp src-address=100.64.3.0/24 to-addresses=3.2.1.0/24 to-ports=4048-5055
add action=netmap chain=100010-CGN protocol=tcp src-address=100.64.4.0/24 to-addresses=3.2.1.0/24 to-ports=5056-6063
add action=netmap chain=100010-CGN protocol=tcp src-address=100.64.5.0/24 to-addresses=3.2.1.0/24 to-ports=6064-7071
add action=netmap chain=100011-CGN protocol=tcp src-address=100.64.6.0/24 to-addresses=3.2.1.0/24 to-ports=7072-8079
add action=netmap chain=100011-CGN protocol=tcp src-address=100.64.7.0/24 to-addresses=3.2.1.0/24 to-ports=8080-9087
add action=netmap chain=100100-CGN protocol=tcp src-address=100.64.8.0/24 to-addresses=3.2.1.0/24 to-ports=9088-10095
add action=netmap chain=100100-CGN protocol=tcp src-address=100.64.9.0/24 to-addresses=3.2.1.0/24 to-ports=10096-11103
add action=netmap chain=100101-CGN protocol=tcp src-address=100.64.10.0/24 to-addresses=3.2.1.0/24 to-ports=11104-12111
add action=netmap chain=100101-CGN protocol=tcp src-address=100.64.11.0/24 to-addresses=3.2.1.0/24 to-ports=12112-13119
add action=netmap chain=100110-CGN protocol=tcp src-address=100.64.12.0/24 to-addresses=3.2.1.0/24 to-ports=13120-14127
add action=netmap chain=100110-CGN protocol=tcp src-address=100.64.13.0/24 to-addresses=3.2.1.0/24 to-ports=14128-15135
add action=netmap chain=100111-CGN protocol=tcp src-address=100.64.14.0/24 to-addresses=3.2.1.0/24 to-ports=15136-16143
add action=netmap chain=100111-CGN protocol=tcp src-address=100.64.15.0/24 to-addresses=3.2.1.0/24 to-ports=16144-17151
add action=netmap chain=101000-CGN protocol=tcp src-address=100.64.16.0/24 to-addresses=3.2.1.0/24 to-ports=17152-18159
add action=netmap chain=101000-CGN protocol=tcp src-address=100.64.17.0/24 to-addresses=3.2.1.0/24 to-ports=18160-19167
add action=netmap chain=101001-CGN protocol=tcp src-address=100.64.18.0/24 to-addresses=3.2.1.0/24 to-ports=19168-20175
add action=netmap chain=101001-CGN protocol=tcp src-address=100.64.19.0/24 to-addresses=3.2.1.0/24 to-ports=20176-21183
add action=netmap chain=101010-CGN protocol=tcp src-address=100.64.20.0/24 to-addresses=3.2.1.0/24 to-ports=21184-22191
add action=netmap chain=101010-CGN protocol=tcp src-address=100.64.21.0/24 to-addresses=3.2.1.0/24 to-ports=22192-23199
add action=netmap chain=101011-CGN protocol=tcp src-address=100.64.22.0/24 to-addresses=3.2.1.0/24 to-ports=23200-24207
add action=netmap chain=101011-CGN protocol=tcp src-address=100.64.23.0/24 to-addresses=3.2.1.0/24 to-ports=24208-25215
add action=netmap chain=101100-CGN protocol=tcp src-address=100.64.24.0/24 to-addresses=3.2.1.0/24 to-ports=25216-26223
add action=netmap chain=101100-CGN protocol=tcp src-address=100.64.25.0/24 to-addresses=3.2.1.0/24 to-ports=26224-27231
add action=netmap chain=101101-CGN protocol=tcp src-address=100.64.26.0/24 to-addresses=3.2.1.0/24 to-ports=27232-28239
add action=netmap chain=101101-CGN protocol=tcp src-address=100.64.27.0/24 to-addresses=3.2.1.0/24 to-ports=28240-29247
add action=netmap chain=101110-CGN protocol=tcp src-address=100.64.28.0/24 to-addresses=3.2.1.0/24 to-ports=29248-30255
add action=netmap chain=101110-CGN protocol=tcp src-address=100.64.29.0/24 to-addresses=3.2.1.0/24 to-ports=30256-31263
add action=netmap chain=101111-CGN protocol=tcp src-address=100.64.30.0/24 to-addresses=3.2.1.0/24 to-ports=31264-32271
add action=netmap chain=101111-CGN protocol=tcp src-address=100.64.31.0/24 to-addresses=3.2.1.0/24 to-ports=32272-33279
add action=netmap chain=110000-CGN protocol=tcp src-address=100.64.32.0/24 to-addresses=3.2.1.0/24 to-ports=33280-34287
add action=netmap chain=110000-CGN protocol=tcp src-address=100.64.33.0/24 to-addresses=3.2.1.0/24 to-ports=34288-35295
add action=netmap chain=110001-CGN protocol=tcp src-address=100.64.34.0/24 to-addresses=3.2.1.0/24 to-ports=35296-36303
add action=netmap chain=110001-CGN protocol=tcp src-address=100.64.35.0/24 to-addresses=3.2.1.0/24 to-ports=36304-37311
add action=netmap chain=110010-CGN protocol=tcp src-address=100.64.36.0/24 to-addresses=3.2.1.0/24 to-ports=37312-38319
add action=netmap chain=110010-CGN protocol=tcp src-address=100.64.37.0/24 to-addresses=3.2.1.0/24 to-ports=38320-39327
add action=netmap chain=110011-CGN protocol=tcp src-address=100.64.38.0/24 to-addresses=3.2.1.0/24 to-ports=39328-40335
add action=netmap chain=110011-CGN protocol=tcp src-address=100.64.39.0/24 to-addresses=3.2.1.0/24 to-ports=40336-41343
add action=netmap chain=110100-CGN protocol=tcp src-address=100.64.40.0/24 to-addresses=3.2.1.0/24 to-ports=41344-42352
add action=netmap chain=110100-CGN protocol=tcp src-address=100.64.41.0/24 to-addresses=3.2.1.0/24 to-ports=42352-43359
add action=netmap chain=110101-CGN protocol=tcp src-address=100.64.42.0/24 to-addresses=3.2.1.0/24 to-ports=43360-44367
add action=netmap chain=110101-CGN protocol=tcp src-address=100.64.43.0/24 to-addresses=3.2.1.0/24 to-ports=44368-45375
add action=netmap chain=110110-CGN protocol=tcp src-address=100.64.44.0/24 to-addresses=3.2.1.0/24 to-ports=45376-46383
add action=netmap chain=110110-CGN protocol=tcp src-address=100.64.45.0/24 to-addresses=3.2.1.0/24 to-ports=46384-47391
add action=netmap chain=110111-CGN protocol=tcp src-address=100.64.46.0/24 to-addresses=3.2.1.0/24 to-ports=47392-48399
add action=netmap chain=110111-CGN protocol=tcp src-address=100.64.47.0/24 to-addresses=3.2.1.0/24 to-ports=48400-49407
add action=netmap chain=111000-CGN protocol=tcp src-address=100.64.48.0/24 to-addresses=3.2.1.0/24 to-ports=49408-50415
add action=netmap chain=111000-CGN protocol=tcp src-address=100.64.49.0/24 to-addresses=3.2.1.0/24 to-ports=50416-51423
add action=netmap chain=111001-CGN protocol=tcp src-address=100.64.50.0/24 to-addresses=3.2.1.0/24 to-ports=51424-52431
add action=netmap chain=111001-CGN protocol=tcp src-address=100.64.51.0/24 to-addresses=3.2.1.0/24 to-ports=52432-53439
add action=netmap chain=111010-CGN protocol=tcp src-address=100.64.52.0/24 to-addresses=3.2.1.0/24 to-ports=53440-54447
add action=netmap chain=111010-CGN protocol=tcp src-address=100.64.53.0/24 to-addresses=3.2.1.0/24 to-ports=54448-55455
add action=netmap chain=111011-CGN protocol=tcp src-address=100.64.54.0/24 to-addresses=3.2.1.0/24 to-ports=55456-56463
add action=netmap chain=111011-CGN protocol=tcp src-address=100.64.55.0/24 to-addresses=3.2.1.0/24 to-ports=56464-57471
add action=netmap chain=111100-CGN protocol=tcp src-address=100.64.56.0/24 to-addresses=3.2.1.0/24 to-ports=57472-58479
add action=netmap chain=111100-CGN protocol=tcp src-address=100.64.57.0/24 to-addresses=3.2.1.0/24 to-ports=58480-59487
add action=netmap chain=111101-CGN protocol=tcp src-address=100.64.58.0/24 to-addresses=3.2.1.0/24 to-ports=59488-60495
add action=netmap chain=111101-CGN protocol=tcp src-address=100.64.59.0/24 to-addresses=3.2.1.0/24 to-ports=60496-61503
add action=netmap chain=111110-CGN protocol=tcp src-address=100.64.60.0/24 to-addresses=3.2.1.0/24 to-ports=61504-62511
add action=netmap chain=111110-CGN protocol=tcp src-address=100.64.61.0/24 to-addresses=3.2.1.0/24 to-ports=62512-63519
add action=netmap chain=111111-CGN protocol=tcp src-address=100.64.62.0/24 to-addresses=3.2.1.0/24 to-ports=63520-64527
add action=netmap chain=111111-CGN protocol=tcp src-address=100.64.63.0/24 to-addresses=3.2.1.0/24 to-ports=64528-65535
add action=netmap chain=100000-CGN protocol=udp src-address=100.64.0.0/24 to-addresses=3.2.1.0/24 to-ports=1024-2031 comment=/24UDP
add action=netmap chain=100000-CGN protocol=udp src-address=100.64.1.0/24 to-addresses=3.2.1.0/24 to-ports=2032-3039
add action=netmap chain=100001-CGN protocol=udp src-address=100.64.2.0/24 to-addresses=3.2.1.0/24 to-ports=3040-4047
add action=netmap chain=100001-CGN protocol=udp src-address=100.64.3.0/24 to-addresses=3.2.1.0/24 to-ports=4048-5055
add action=netmap chain=100010-CGN protocol=udp src-address=100.64.4.0/24 to-addresses=3.2.1.0/24 to-ports=5056-6063
add action=netmap chain=100010-CGN protocol=udp src-address=100.64.5.0/24 to-addresses=3.2.1.0/24 to-ports=6064-7071
add action=netmap chain=100011-CGN protocol=udp src-address=100.64.6.0/24 to-addresses=3.2.1.0/24 to-ports=7072-8079
add action=netmap chain=100011-CGN protocol=udp src-address=100.64.7.0/24 to-addresses=3.2.1.0/24 to-ports=8080-9087
add action=netmap chain=100100-CGN protocol=udp src-address=100.64.8.0/24 to-addresses=3.2.1.0/24 to-ports=9088-10095
add action=netmap chain=100100-CGN protocol=udp src-address=100.64.9.0/24 to-addresses=3.2.1.0/24 to-ports=10096-11103
add action=netmap chain=100101-CGN protocol=udp src-address=100.64.10.0/24 to-addresses=3.2.1.0/24 to-ports=11104-12111
add action=netmap chain=100101-CGN protocol=udp src-address=100.64.11.0/24 to-addresses=3.2.1.0/24 to-ports=12112-13119
add action=netmap chain=100110-CGN protocol=udp src-address=100.64.12.0/24 to-addresses=3.2.1.0/24 to-ports=13120-14127
add action=netmap chain=100110-CGN protocol=udp src-address=100.64.13.0/24 to-addresses=3.2.1.0/24 to-ports=14128-15135
add action=netmap chain=100111-CGN protocol=udp src-address=100.64.14.0/24 to-addresses=3.2.1.0/24 to-ports=15136-16143
add action=netmap chain=100111-CGN protocol=udp src-address=100.64.15.0/24 to-addresses=3.2.1.0/24 to-ports=16144-17151
add action=netmap chain=101000-CGN protocol=udp src-address=100.64.16.0/24 to-addresses=3.2.1.0/24 to-ports=17152-18159
add action=netmap chain=101000-CGN protocol=udp src-address=100.64.17.0/24 to-addresses=3.2.1.0/24 to-ports=18160-19167
add action=netmap chain=101001-CGN protocol=udp src-address=100.64.18.0/24 to-addresses=3.2.1.0/24 to-ports=19168-20175
add action=netmap chain=101001-CGN protocol=udp src-address=100.64.19.0/24 to-addresses=3.2.1.0/24 to-ports=20176-21183
add action=netmap chain=101010-CGN protocol=udp src-address=100.64.20.0/24 to-addresses=3.2.1.0/24 to-ports=21184-22191
add action=netmap chain=101010-CGN protocol=udp src-address=100.64.21.0/24 to-addresses=3.2.1.0/24 to-ports=22192-23199
add action=netmap chain=101011-CGN protocol=udp src-address=100.64.22.0/24 to-addresses=3.2.1.0/24 to-ports=23200-24207
add action=netmap chain=101011-CGN protocol=udp src-address=100.64.23.0/24 to-addresses=3.2.1.0/24 to-ports=24208-25215
add action=netmap chain=101100-CGN protocol=udp src-address=100.64.24.0/24 to-addresses=3.2.1.0/24 to-ports=25216-26223
add action=netmap chain=101100-CGN protocol=udp src-address=100.64.25.0/24 to-addresses=3.2.1.0/24 to-ports=26224-27231
add action=netmap chain=101101-CGN protocol=udp src-address=100.64.26.0/24 to-addresses=3.2.1.0/24 to-ports=27232-28239
add action=netmap chain=101101-CGN protocol=udp src-address=100.64.27.0/24 to-addresses=3.2.1.0/24 to-ports=28240-29247
add action=netmap chain=101110-CGN protocol=udp src-address=100.64.28.0/24 to-addresses=3.2.1.0/24 to-ports=29248-30255
add action=netmap chain=101110-CGN protocol=udp src-address=100.64.29.0/24 to-addresses=3.2.1.0/24 to-ports=30256-31263
add action=netmap chain=101111-CGN protocol=udp src-address=100.64.30.0/24 to-addresses=3.2.1.0/24 to-ports=31264-32271
add action=netmap chain=101111-CGN protocol=udp src-address=100.64.31.0/24 to-addresses=3.2.1.0/24 to-ports=32272-33279
add action=netmap chain=110000-CGN protocol=udp src-address=100.64.32.0/24 to-addresses=3.2.1.0/24 to-ports=33280-34287
add action=netmap chain=110000-CGN protocol=udp src-address=100.64.33.0/24 to-addresses=3.2.1.0/24 to-ports=34288-35295
add action=netmap chain=110001-CGN protocol=udp src-address=100.64.34.0/24 to-addresses=3.2.1.0/24 to-ports=35296-36303
add action=netmap chain=110001-CGN protocol=udp src-address=100.64.35.0/24 to-addresses=3.2.1.0/24 to-ports=36304-37311
add action=netmap chain=110010-CGN protocol=udp src-address=100.64.36.0/24 to-addresses=3.2.1.0/24 to-ports=37312-38319
add action=netmap chain=110010-CGN protocol=udp src-address=100.64.37.0/24 to-addresses=3.2.1.0/24 to-ports=38320-39327
add action=netmap chain=110011-CGN protocol=udp src-address=100.64.38.0/24 to-addresses=3.2.1.0/24 to-ports=39328-40335
add action=netmap chain=110011-CGN protocol=udp src-address=100.64.39.0/24 to-addresses=3.2.1.0/24 to-ports=40336-41343
add action=netmap chain=110100-CGN protocol=udp src-address=100.64.40.0/24 to-addresses=3.2.1.0/24 to-ports=41344-42352
add action=netmap chain=110100-CGN protocol=udp src-address=100.64.41.0/24 to-addresses=3.2.1.0/24 to-ports=42352-43359
add action=netmap chain=110101-CGN protocol=udp src-address=100.64.42.0/24 to-addresses=3.2.1.0/24 to-ports=43360-44367
add action=netmap chain=110101-CGN protocol=udp src-address=100.64.43.0/24 to-addresses=3.2.1.0/24 to-ports=44368-45375
add action=netmap chain=110110-CGN protocol=udp src-address=100.64.44.0/24 to-addresses=3.2.1.0/24 to-ports=45376-46383
add action=netmap chain=110110-CGN protocol=udp src-address=100.64.45.0/24 to-addresses=3.2.1.0/24 to-ports=46384-47391
add action=netmap chain=110111-CGN protocol=udp src-address=100.64.46.0/24 to-addresses=3.2.1.0/24 to-ports=47392-48399
add action=netmap chain=110111-CGN protocol=udp src-address=100.64.47.0/24 to-addresses=3.2.1.0/24 to-ports=48400-49407
add action=netmap chain=111000-CGN protocol=udp src-address=100.64.48.0/24 to-addresses=3.2.1.0/24 to-ports=49408-50415
add action=netmap chain=111000-CGN protocol=udp src-address=100.64.49.0/24 to-addresses=3.2.1.0/24 to-ports=50416-51423
add action=netmap chain=111001-CGN protocol=udp src-address=100.64.50.0/24 to-addresses=3.2.1.0/24 to-ports=51424-52431
add action=netmap chain=111001-CGN protocol=udp src-address=100.64.51.0/24 to-addresses=3.2.1.0/24 to-ports=52432-53439
add action=netmap chain=111010-CGN protocol=udp src-address=100.64.52.0/24 to-addresses=3.2.1.0/24 to-ports=53440-54447
add action=netmap chain=111010-CGN protocol=udp src-address=100.64.53.0/24 to-addresses=3.2.1.0/24 to-ports=54448-55455
add action=netmap chain=111011-CGN protocol=udp src-address=100.64.54.0/24 to-addresses=3.2.1.0/24 to-ports=55456-56463
add action=netmap chain=111011-CGN protocol=udp src-address=100.64.55.0/24 to-addresses=3.2.1.0/24 to-ports=56464-57471
add action=netmap chain=111100-CGN protocol=udp src-address=100.64.56.0/24 to-addresses=3.2.1.0/24 to-ports=57472-58479
add action=netmap chain=111100-CGN protocol=udp src-address=100.64.57.0/24 to-addresses=3.2.1.0/24 to-ports=58480-59487
add action=netmap chain=111101-CGN protocol=udp src-address=100.64.58.0/24 to-addresses=3.2.1.0/24 to-ports=59488-60495
add action=netmap chain=111101-CGN protocol=udp src-address=100.64.59.0/24 to-addresses=3.2.1.0/24 to-ports=60496-61503
add action=netmap chain=111110-CGN protocol=udp src-address=100.64.60.0/24 to-addresses=3.2.1.0/24 to-ports=61504-62511
add action=netmap chain=111110-CGN protocol=udp src-address=100.64.61.0/24 to-addresses=3.2.1.0/24 to-ports=62512-63519
add action=netmap chain=111111-CGN protocol=udp src-address=100.64.62.0/24 to-addresses=3.2.1.0/24 to-ports=63520-64527
add action=netmap chain=111111-CGN protocol=udp src-address=100.64.63.0/24 to-addresses=3.2.1.0/24 to-ports=64528-65535
add action=netmap chain=srcnat protocol=icmp src-address=100.64.0.0/18 to-addresses=3.2.1.0/24 comment=/18ICMP
The only thing your NATing Router needs to have besides the code above is two transfer networks (in and out) as well as a Default route for the internet-facing side (out).
The customer traffic needs to be pushed into the internal side interface.
