Hope someone could shed some light and point me in the right direction!
I have a working CAPsMan installation which controls about 15 units. WiFi generally works very well, but I came to the wall in a large storage area. I have a situation where devices seem to have very high signal levels, yer fall out or have weak transfer rather often. I also get stuff like failed 4-way handshake on good signal, etc.
As I haven’t defined any specific channels, and devices select a range of channels, like: 1, 3, 4, 5, 7 and 11. Also, I left the devices without setting the power transmit levels to get max power, however that doesn’t seem to work that well. While I seem to have loads of signal, devices seem to be too weak to send to the AP itself.
How can I diagnose the issues at hand and what to do to fix them? I tried using the access list to allow and limit access, but that didn’t work that well, not sure how the signal level is calculated: from device or to (how?) device.
This is my first larger installation, so I would appreciate some help on how to set everything to work stable. THANKS! ![]()
This is the config:
# sep/04/2019 20:06:15 by RouterOS 6.44.5
# model = RouterBOARD 3011UiAS
/caps-man configuration
add channel.band=2ghz-onlyn channel.control-channel-width=20mhz channel.extension-channel=disabled channel.reselect-interval=1h channel.save-selected=yes \
comment="2.4GHz DILCOM / MASTER" country=no_country_set datapath.bridge=WiFi-DILCOM distance=indoors installation=indoor mode=ap name=DILCOM \
security.authentication-types=wpa2-psk security.encryption=aes-ccm security.passphrase=superpass ssid=DILCOM
add datapath.bridge=WiFi-GOSTI mode=ap name=GUESTS security.authentication-types=wpa2-psk security.encryption=aes-ccm security.passphrase=superpass \
ssid=GUESTS
add datapath.bridge=DILCOM mode=ap name="LINK 2.4GHz" security.authentication-types=wpa2-psk security.encryption=aes-ccm security.passphrase=\
KongPass ssid=LINK
add datapath.bridge=WiFi-WAREHOUSE mode=ap name=WAREHOUSE security.authentication-types=wpa2-psk security.encryption=aes-ccm security.group-key-update=15m \
security.passphrase=Frog12! ssid=WAREHOUSE
add channel.band=5ghz-onlyac channel.extension-channel=disabled channel.reselect-interval=1h channel.save-selected=yes comment="5GHz LINK / MASTER" country=\
no_country_set datapath.bridge=DILCOM distance=dynamic installation=any name="LINK 5GHz" security.authentication-types=wpa2-psk security.encryption=\
aes-ccm security.passphrase=FrogX ssid=LINK
/caps-man aaa
set called-format=mac:ssid interim-update=disabled mac-caching=disabled mac-format=XX:XX:XX:XX:XX:XX mac-mode=as-username
/caps-man access-list
#next three rules are not used
add allow-signal-out-of-range=10s ap-tx-limit=1000000 comment="GUESTS limit, 500k -> 3.5MB/s" disabled=no ssid-regexp=GUESTS
add action=reject allow-signal-out-of-range=10s disabled=yes interface=all signal-range=-120..-80 ssid-regexp=""
add action=accept allow-signal-out-of-range=10s disabled=yes interface=all signal-range=-79..120 ssid-regexp=""
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes package-path=/capsman require-peer-certificate=no upgrade-policy=suggest-same-version
/caps-man manager interface
set [ find default=yes ] disabled=no forbid=yes interface=all
add disabled=no forbid=no interface=DILCOM
/caps-man provisioning
add action=create-dynamic-enabled common-name-regexp="" disabled=no hw-supported-modes=gn identity-regexp="" ip-address-ranges="" master-configuration=\
DILCOM name-format=prefix-identity name-prefix=CAP-2.4GHz radio-mac=00:00:00:00:00:00 slave-configurations="WAREHOUSE,GUESTS,LINK 2.4GHz"
add action=create-dynamic-enabled common-name-regexp="" disabled=no hw-supported-modes=ac identity-regexp="" ip-address-ranges="" master-configuration=\
"LINK 5GHz" name-format=prefix-identity name-prefix=CAP-5GHz radio-mac=00:00:00:00:00:00 slave-configurations=DILCOM
