Hi guys
I am having a problem with my RB433
My laptop cannot detect any of the ethernet ports when connected and I need to configure it
So I thinks resetting will work but after pressing a button I saw on the board for some seconds nothing seems to have happened.
Please, How can I reset RB433
I dont have a console cable as well
You can’t connect to the routerboard using the mac-address in winbox?
I can’t
Neither MAC or IP is working
Then you have to borrow or buy serial cable, because there is no reset jumpers on RB433
of course there is a reset jumper on RB433, just as on all RouterBOARD models.
follow instructions here:
http://wiki.mikrotik.com/wiki/MikroTik_Password_Recovery
Oh, that’s good, I didn’t know that there is a reset hole ![]()
I got that
