Only ether1 (WAN) and ether2 (LAN) are in use. Soon this will be ether1 (WAN) and sfp1 (LAN).
What I would like to is have the WAN network available on a tagged VLAN on the LAN bridge side, such as VLAN 4050. So that this way when a device on the LAN side is set to this VLAN, that they can access the network the WAN port is plugged into.
Is this possible and if yes, how can this be done?
Your explanation is lacking… do you want the vlan to be assigned a public IP address?
Or you simple want users on that vlan to be able to access the internet.??
My bad. I’d like systems on this VLAN to be able to access the WAN network directly, so each system could set its own static public IP address, no features from the router other than passing through traffic.
Best way IMO would be to convert your current WAN+LAN setup to all-VLAN setup. So you would add all ports (including current WAN port to same bridge and use one VLAN for WAN and another VLAN for LAN. Your current WAN port (ether1) would be access port for WAN VLAN, some ports would be access ports for LAN VLAN or WAN VLAN or trunk ports for both VLANs … all of this very much depends on how your LAN infrastructure looks like (any smart switches, where do various devices connect, etc.).
If you don’t know how to do VLANs, here’s tutorial. Setup will work, but suboptimal on your hardware since explained setup runs entirely on CPU. You could setup similar config using switch chip VLAN handling, it’s slightly more complex and easier to lock self out of device. You can start off using bridge config and later convert it to switch chip if the perfornance will not be satisfactory.
If other LAN infrastructure doesn’t require trunk ports (because RB is only switch and all devices connect directly or intended WAN devices connect either directly or to dedicated switch), then you can go with two bridges, one for WAN and another for LAN. A gotcha: one switch chip can only offload single bridge, your RB has two switch chips (one running ports ether1-ether5, the other running ether6-ether10), so you should group ports carefully. If you want to use RB ad firewall also for WAN devices, those ports can’t be offloaded anyway so you can even go with a software-run bridge (if traffic between the WAN devices won’t be huge).
If there’s a switch for WAN devices, then you can connect it between ISP and RB. This setup completely bypasses RB for other WAN devices, so RB’s firewall won’t protect them.
I am on the same situation with this setup. Did you found any solution?
This is my current set up on the router: rb750
ether1 = WAN
ether2-5 (bridge1) = LAN
while dhcp, gateway and scnat for clients is at bridge1 I want to add a vlan x on all ether 2-5 ports to extend the WAN subnet over this vlan. (so this means ether2-5 ports will be hybrid).
So all clients get the dhcp and access internet on untagged native vlan 1
and special clients get the ip on wan address range via tagged vlan x
so far I have tried multiple combination with vlan on ether1 and include to the bridge1. vlan on bridge1 and second bridge2 with ether1 but its not working.
