How to setup Dual wan as (Bonded)
Guys,
I’m using RB493AH and i have existing 1 DSL at the moment but i plan to add another 1 DSL this june so i just want to ask your help setting up DUAL WAN (BONDED) for my RB493AH. both DSL account use PPOE and how to enable NAT on port ether3 because ether1 and ether9 will be use as WAN port.
ether3 & ether 4 IP: 10.10.10.254 (Bridge Mode)
ether5 IP: 10.10.1.254
ether6 IP: 10.10.2.254 so on and so forth.
Thanks in advance for your help.
@ Alex
f provider supports mlpppoe, then you can bond both links by setting up mlpppoe link.
Thank you. Bonded is not my option right now and i will to ask my provider if they support multi link ppoe.
I will go for Load Balancing, could someone help me the config for my RB493AH.
thanks
