How to setup L2TP VPN?
How can I set up L2TP vpn?
It is very difficult on Mikrotik
I have followed several guides and youtube.
but i cannot get a connection so i can access a server on my lan network
Is there anyone who can help me?
I don’t want the default config 192.168.89.1
i want to get to my lan network 10.0.0.0/23
[admin@Landaal-MK] > ip address export
# mar/22/2020 13:31:23 by RouterOS 6.46.4
# software id = 4ZV9-XS2V
# model = 960PGS
# serial number = 78D207A03485
add address=10.0.0.1/23 comment=defconf interface=ether2 network=10.0.0.0
add address=10.0.3.1/24 interface=vlan3 network=10.0.3.0
Did you check the examples in the wiki ?
https://wiki.mikrotik.com/wiki/Manual:Interface/L2TP#Application_Examples
Of course!
I can set up a VPN.
then when i am connected to the vpn i cannot access my server locally on 10.0.0.200/23
Is the VPN subnet the same as in your Local network ?
If yes then try enabling proxy-arp in your Bridge interface and test again…
Otherwise you should use NAT to reach your server…
hmm i think the subnet is the problem. local is / 23 vpn is / 24. where can I change the vpn subnet? I can’t find this
/23 and /24 already have a common address space…
So if you cant reach any IP, that cant be the problem…
Can you type the whole addresses ?
Yes,
my private network is 10.0.0.0/23 and te router is 10.0.0.1
My guest network is vlan 10.0.3.0/24 router 10.0.3.1
here the vpn details
 name="wesley" service=l2tp caller-id="" password="********"
     profile=default local-address=10.0.0.1 remote-address=10.0.0.10 routes=""
     limit-bytes-in=0 limit-bytes-out=0 last-logged-out=jan/01/1970 00:00:00
[admin@Landaal-MK] /interface ethernet> print
Flags: X - disabled, R - running, S - slave
 #    NAME               MTU MAC-ADDRESS       ARP             SWITCH
 0 R  ;;; Ziggo-WAN
      ether1-wan        1500 64:D1:54:A8:F1:30 enabled         switch1
 1 RS ether2            1500 64:D1:54:A8:F1:31 proxy-arp       switch1
 2  S ether3            1500 64:D1:54:A8:F1:32 enabled         switch1
 3  S ether4            1500 64:D1:54:A8:F1:33 enabled         switch1
 4  S ether5            1500 64:D1:54:A8:F1:34 enabled         switch1
 5  S sfp1              1500 64:D1:54:A8:F1:35 enabled
when i make a connection i get a 24 subnet and not 23
Here a output of my windows machine
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::ac12:62e8:d35:4220%16
   IPv4 Address. . . . . . . . . . . : 10.0.0.51
   Subnet Mask . . . . . . . . . . . : 255.255.254.0
   Default Gateway . . . . . . . . . : 10.0.0.1
PPP adapter Home:
   IPv4 Address. . . . . . . . . . . : 10.0.0.10
   Subnet Mask . . . . . . . . . . . : 255.255.255.255
   Default Gateway . . . . . . . . . : 0.0.0.0
Hope you can help me
I am confused.
Earlier you said the VPN Subnet is the 10.0.3.0/24..
But as i can see from your code, the remote-address you use for the VPN Client is 10.0.0.10, so you are in the same subnet as your Local network…
Enable proxy ARP on your Bridge interface and try again…
Also, as i see IPv4 Address. . . . . . . . . . . : 10.0.0.51 makes me more confused…
Are you inside your LAN but you connect through VPN to access the Server inside your LAN ? :confused:
Yes my guest and vpn are /24 networks.
vpn network was 192.168.89.1 /24
I have change it to the same subnet as my private lan.
My lan start at 10.0.0.50
So i give my vpn the 10.0.0.10 adress.
This wil Works right..
I set proxy ARP on the bridge.
I have make on multiple routers a vpn connection.
But mikrotik is difficult
It is not about Mikrotik, it is about Netowrks in general…
So did it work ?
No its not working
Verstuurd vanaf mijn SM-A505FN met Tapatalk
Are you sure you are not blocking anything with Firewall ?
When you are connected through the VPN, can you ping the VPN Address of the router ? 10.0.3.x ?
I check it tomorrow. Tonight a have no time :frowning:
I can make a VPN connection from the inside.
When I am on 4G network I cannot make the connection.
Here an output from my firewall
[admin@Landaal-MK] /ip firewall filter> print
 0  D ;;; Laptop Levy, kid-control
      chain=forward action=reject dst-address=10.0.0.232
 1  D ;;; Laptop Levy, kid-control
      chain=forward action=reject src-address=10.0.0.232
 2  D ;;; Levy mobiel, kid-control
      chain=forward action=reject dst-address=10.0.0.93
 3  D ;;; Levy mobiel, kid-control
      chain=forward action=reject src-address=10.0.0.93
 4  D ;;; Tablet Izzaly, kid-control
      chain=forward action=reject dst-address=10.0.0.175
 5  D ;;; Tablet Izzaly, kid-control
      chain=forward action=reject src-address=10.0.0.175
 6  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 7    ;;; defconf: accept established,related,untracked
      chain=input action=accept
      connection-state=established,related,untracked log=no log-prefix=""
 8    ;;; allow pptp
      chain=input action=accept protocol=tcp dst-port=1723
 9    ;;; defconf: drop invalid
      chain=input action=drop connection-state=invalid
10    ;;; defconf: accept ICMP
      chain=forward action=drop protocol=icmp log=no log-prefix=""
11    ;;; defconf: accept to local loopback (for CAPsMAN)
      chain=input action=accept dst-address=127.0.0.1
12    ;;; defconf: drop all not coming from LAN
      chain=input action=drop in-interface-list=!LAN
13    ;;; defconf: accept in ipsec policy
      chain=forward action=accept ipsec-policy=in,ipsec
14    ;;; defconf: accept out ipsec policy
      chain=forward action=accept ipsec-policy=out,ipsec
15    ;;; defconf: fasttrack
      chain=forward action=fasttrack-connection
      connection-state=established,related log=no log-prefix=""
16    ;;; defconf: accept established,related, untracked
17    ;;; defconf: drop invalid
      chain=forward action=drop connection-state=invalid
18    ;;; defconf: drop all from WAN not DSTNATed
      chain=forward action=drop connection-state=new
      connection-nat-state=!dstnat in-interface-list=WAN
19    ;;; Block guest network from home network
      connection-state=invalid,established,related,new,untracked
      src-address-list=Home-Network log=no log-prefix=""
20    chain=forward action=accept connection-state=established,related
21    ;;; Emby Access from guest network
      chain=forward action=accept protocol=tcp src-address=10.0.3.0/24
      dst-address=10.0.0.200 dst-port=8096 log=no log-prefix=""
22    ;;; Minecraft access from guest network
      chain=forward action=accept protocol=udp src-address=10.0.3.0/24
      dst-address=10.0.0.200 dst-port=19132 log=no log-prefix=""
23    ;;; webserver from guest network
      dst-address=10.0.0.200 dst-port=80 log=no log-prefix=""
24    ;;; webserver from guest network
      dst-address=10.0.0.200 dst-port=443 log=no log-prefix=""
25    ;;; Block all acces from guest network to home network
      chain=forward action=drop in-interface=vlan3 out-interface=bridge
-- [Q quit|D dump|up|down]
But earlier you said the VPN connection is established… :open_mouth:
Yes 2 days ago was it working on a different subnet
Now is only working form inside
I posted this in another thread recently. This should be pretty close. It assumes RADIUS, but I’d guess it isn’t hard to authenticate against a local database.
 add name=pool.ppp ranges=172.20.0.10-172.20.0.50
/ppp profile
 add interface-list=ifl.vpn.trusted local-address=172.20.0.1 name=pr.l2tp only-one=yes remote-address=pool.ppp use-encryption=required use-upnp=no
/ppp aaa
 set accounting=no use-radius=yes
/radius
 add address=172.16.5.22 secret=<RADIUS PSK> service=ppp timeout=2s
/interface l2tp-server
 add name=l2tp-in1 user=""
/interface l2tp-server server
 set authentication=mschap2 default-profile=pr.l2tp enabled=yes ipsec-secret=<PSK> one-session-per-host=yes use-ipsec=required
/ip ipsec proposal
 set [ find default=yes ] auth-algorithms=sha512,sha256,sha1 enc-algorithms=aes-256-cbc pfs-group=modp4096
 add action=jump chain=forward in-interface-list=ifl.vpn.trusted jump-target=vpn.trusted.in
 add action=passthrough chain=--------
 add action=accept chain=vpn.trusted.in comment=VoIP dst-address=172.16.5.16 protocol=udp src-port=3000-3001,4000-4005
 add action=accept chain=vpn.trusted.in icmp-options=8:0-255 protocol=icmp
 add action=drop chain=vpn.trusted.in log=yes log-prefix="Def Drop: "
With Windows, you can create the VPN connection with Powershell. This is the example I use. You may need to adjust some options for compatibility with your configuration.
Add-VpnConnection -Name "SLHV CNE" -ServerAddress "<FQDN or IP>" -AllUserConnection:$true -AuthenticationMethod MSChapv2 -TunnelType L2TP -l2tppsk "<PSK>" -SplitTunnel:$false -EncryptionLevel Required -UseWinlogonCredential -PassThru -Force
When i disable this rule
Than i can make connection from outside.
Tested with mobile and i can Access the router.
But i can see on my mobile of i have the same subnet
I provided the sample code as a template for you to refer to. It is primarily geared for starting with no L2TP configuration. If you have any configuration that may conflict, you’ll have to diagnose and resolve it.
Your rule 12 is a very important rule that you should not disable until you understand what it does, and are able to weigh and mitigate the risks associated with disabling that rule. That particular rule is a very strong impediment to compromise of your router and network(s) due to malicious activity.
If you don’t understand what the firewall rules are for, I strongly encourage you to spend more time studying networking before exposing things to the internet.
Tippenring,
It was not a wrong config of the l2tp-vpn.
it was a firewall problem.
found firewall rule that got in the way.
And adjusted this line.
I’ve been doing networking stuff for a bit longer than today;)
I have overlooked all these.
