How to setup Port Forwarding with LTE
I have a mikrotik B952Ui-5ac2nD with LTE USB modem, that I can’t get static IP for my LTE modem.
How can I config my router to use port forwarding.
thanks.
Basically one needs
sourcnat rule
dst-nat rule for the port forwarding itself.
forward chain filter rule allowing dst-nat in general.
From basic defaults all in in place except the dst-nat rule.
Req:
  • Your ISP must give you a Public IP, if it;s not public then you not do a DNAT. He not must by static, with dynamic you can use IP > Cloud as DDNS.
  • Your USB modem must support DMZ feature if you see lte1 interface at ROS means he must give Public IP from ISP to MikroTik.
Then you can do like @anav say.
hi Sib, just started watching a Polish netflix TV series last night called “the woods” (spoken in Polish but with English subtitles - its the best way to watch foreign films as english dubbing is often so horrible it takes away from films)
I know, I have similar with anime :p. But I start learn Japan form 3mth :smiley:
You are braver than I, but I suspect you wish to travel (not likely in the near term), OR, you have either a local or on-line interest (luv is in the air LOL)
