how to share pptp-out client to socks and http proxy user
hello
i want share pptp-out connection in mikrotik to people that connects with http proxy and socks proxy..how i can do this?
set [ find default-name=ether1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full
/interface pptp-client
add connect-to=test.com disabled=no name=pptp-out1 password=\
    test user=test
add name=pool1 ranges=10.0.0.1-10.0.0.254
/port
set 0 name=serial0
/ppp profile
set *FFFFFFFE dns-server=8.8.8.8 local-address=pool1 remote-address=pool1
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,passw\
    ord,web,sniff,sensitive,api,romon,dude,tikapp"
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2 enabled=yes
/interface sstp-server server
set enabled=yes verify-client-certificate=yes
add address=10.0.0.1/24 interface=ether1 network=10.0.0.0
/ip cloud
set update-time=no
/ip dhcp-client
add disabled=no interface=ether1
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=vpn passthrough=yes \
    src-address=10.0.0.0/24
add action=masquerade chain=srcnat src-address=10.0.0.0/24
add distance=1 gateway=pptp-out1 routing-mark=vpn
/ip socks
set auth-method=password enabled=yes version=5
/ip socks users
add name=test password=test
/ppp secret
add name=test password=test profile=default-encryption
UP!
Proxied connections originate from router, so you can make them use another routing table. But you won’t be able to distinguish them from other router’s own connections (router querying DNS resolver, router checking for updates, even router establishing VPN connection). But if you exclude those in some way, it could be good enough:
/ip firewall mangle
add chain=output connection-state=new action=jump jump-target=new-output
add chain=new-output dst-address=x.x.x.x/x action=return comment="exclude target address or subnet"
add chain=new-output protocol=tcp dst-port=12345 action=return comment="exclude target port"
add chain=new-output action=mark-connection new-connection-mark=to-vpn passthrough=yes
add chain=output connection-mark=to-vpn action=mark-routing new-routing-mark=vpn
